Bleeding Air Conditioning water line - SailNet Community
post #1 of 4 Old 12-30-2008 Thread Starter
Hello:
Our air conditioning water intake needs to be bled every time that the boat heels and the lines lose their water. Closing the intake valves help but is a pain in the ****.
Any suggestions on how to help avoid this?
Are there A/C self-priming pumps worth looking at?
Labestia
labestia is offline
post #2 of 4 Old 12-30-2008
HerbDB's Avatar
The problem with self priming pumps is that they are not rated for the continuous operation that the AC system requires. I had a similar problem on my last boat. I finally put a squeeze bulb pump in the input line, a couple of squeezes would reprime the pump without disconnecting lines.
On that boat, the installer put the thru hull where it was convenient, not at the deepest location possible. I made sure that did not happen on my current boat.
Herb DuBois
Beneteau 36CC
Split Decision
HerbDB is offline
post #3 of 4 Old 12-31-2008
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
If you have a big unity, the bulb might pose some flow restriction. We installed a Y valve at water exit, and ran some lenght of transparent hose with a bulb. Turn the valve then squeeze (or suck) until you see the water coming. Well, still a pain but worked well ....
Nave Rara
Beneteau Oceanis 43
negrini is offline
post #4 of 4 Old 12-31-2008
Sabreman's Avatar
Herb - That is an AWESOME idea!
We have the same problem, but I found that if I shut the intake seacock, I retain the prime. While the A/C is running, I loop the engine key on the seacock handle so that I don't drive the boat away wihout shutting the seacock (I lose the prime when the boat moves and the valve is open).
Every now and then, I lose the prime even with the seacock shut, so the squeeze bulb is a great idea.
Thanks...... I love SailNet.
Sabre 38 "Victoria"
Sabreman is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 03:42 PM
Air in fresh water lines on Pearson 424 pma_foyl Gear & Maintenance 1 06-14-2004 01:35 PM
Getting Good Starts, Part Two Zack Leonard Racing Articles 0 01-15-2004 08:00 PM
Basic Thoughts on Tides Jim Sexton Learning to Sail Articles 0 11-17-2003 08:00 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 06:59 PM
