squealing noise from aft - Page 3 - SailNet Community
post #21 of 31 Old 12-31-2008
Retired and happy
Leither's Avatar
Originally Posted by KindOfBlue View Post
When the boat was serviced a couple of weeks ago, was it hauled at all? You need to burp the dripless stuffing box after every haul/launch.
So, how do you do that, then? Put it over your shoulder and pat its back?? Read SailNet and learn something new every day!
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Leither is offline
post #22 of 31 Old 01-01-2009
Wayne25's Avatar
This is from PSS installation instructions. I have a PSS seal on my inboard and has a pressurized system to feed water for lubrication. Method B in the instructions. If for some reason the dynamics of your hull around the exit point of your prop shaft causes a vacuum during running, it could create a dry seal. I would then go to method B to pressurize the system.
From the instructions:
15. Plumbing the system:
15A. Low speed boatsUnder 12 knots of boat speed under power).
Note:Sailboats or displacement powerboats with a powering speed below 12 knots can use either method A or B.
Using a 3/8 ” ((8 or 9 mm)ID “underwater rated ” hose ((not provided with the PSS), connect the hose to the hose barb fitting installed on the carbon and secure the hose with two (2)hose clamps.Run the hose to a point in the boat at least two (2)feet above the waterline,making sure that the hose does not apply any load on the carbon part of the seal.Keep the hose as close as possible to the centerline of the vessel so the top of the vent hose is never below the waterline,even if the boat heels.Secure the hose in place with the necessary fittings that insure it will not pull free and drop.This hose is now a venting hose that will help ensure that no air is trapped in the seal.
WARNINGS: Do not run a loop at the top end of the vent hose as it could start a siphon action in some extreme conditions.Also,make sure the vent hose is properly secured from falling below the waterline.If the vent hose were to fall down below the waterline, water would come in the boat.Also,do not plug or block the end of the vent hose,as this would prevent the line from venting.
15B.High-speed boatsOver 12 knots of boat speed under power).
Note:Boats that can exceed 12 knots on a single engine must run a crossover line between seals to ensure both seals maintain water flow. For high-speed vessels it is required that a water supply be plumbed to the PSS for the purpose of cooling and lubricating the seal faces (i.e.,at over approximately 12 knots of speed a vacuum is created in the stern tube and water is drawn away from the PSS resulting in a loss of cooling water that may cause the carbon to over heat).There are multiple sources of water for this supply.The following are a few non-exhaustive examples. These are examples only and they may or may not apply to your particular boat.
-T-off the engine raw water-cooling line.(Note:T-kits are available separately from PYI, Inc for internal hose 3/4",1",1 1/4",1 1/2")
-Thread a barb fitting into the drain plug of the heat exchanger if applicable.
-Thread a barb fitting into the drain plug of the exhaust manifold if the manifold is raw water-cooled.
-Add a small scoop under water for keel-cooled boats or t-off another water pick-up.
(Note:A valve must be installed to regulate the water flow as too high a water flow may over pressurize the PSS seal).Use an appropriate “underwater rated ” hose from the fittings on the boat and the fitting on the PSS and secure them with two (2)hose clamps at each end.
NOTICE:All plumbing must follow the standards and practices of proper boat plumbing.
For example,if the pick-up on the engine is located under the waterline,an anti-siphon fitting must me installed,in addition to other standards and practices.
16. Testing:When launching the boat,inspect the PSS and make sure the PSS is properly in place.Water should not be entering the boat from the PSS seal area.Run the engine in gear as in a normal operation.It is normal at this time to notice a very fine spray or mist coming from the seal and some carbon dust,as the PSS requires a break in period (see below).The PSS should not be leaking at rest and should never spray more than just a fine spray or mist.
TROUBLESHOOTING
A.High-pitched squeal:
If you hear a high-pitched squeal from the PSS shaft seal during operation,the seal may not be getting water.Review and correct plumbing to the seal.
CAUTION:If the seal has run dry use caution!The faces (stainless steel rotor and carbon)may be very hot.
Wayne
Rehoboth Bay/Indian River, DE
S/Y KJ, Helms 25
1976 #552
Wayne25 is offline
post #23 of 31 Old 01-01-2009 Thread Starter
Boat has not been hauled out yet,all work done while at the dock,used divers a couple of times for inspections and installations. Plan to take out after sailing season ends, possibly June/July to do the bottom and other maintenance work.
During initial after purchase work we checked all systems and made repairs and upgrades as needed.
The noise could be a problem with the PSS, cutlass bearing, prop shaft or from previous work done, which would be under warranty such as the new transmission,water pump,alternator or from the servicing of many other items.
We will see. I am going to wait for the mechanic to come back from vacation next week.
I am planning to sailing today and spend the first day of the year in the water. Will see if the noise comes back.
Thanks for all the responses.
reycuban is offline
post #24 of 31 Old 01-01-2009 Thread Starter
Well, no noise. Ran the engine for over an hour at intervals and different RPM's up to 2500 RPM's, forward and reverse. For a while headed up wind blowing 20-25 knts.
PSS was cool and no leaks,bilge dry,belts OK. Let's hope it stays like this.
By the way, great sail today. Temp 76 degrees,winds ENE 20-30 knts.Good to live in Miami! Thanks.
reycuban is offline
post #25 of 31 Old 01-01-2009
the pointy end is the bow
erps's Avatar
Our previous boat, a Catalina 34, required burping the PSS shaft seal after I would scrub the bottom using SCUBA gear. That flat bottom was very susceptible to catching bubbles.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #26 of 31 Old 03-12-2009
exact same problem
I have the same noise but i do have a stuffing box did you figure out what the noise was?
thanks
goletasailor is offline
post #27 of 31 Old 03-12-2009 Thread Starter
Shhss. Went away. Long time ago.
reycuban is offline
post #28 of 31 Old 03-12-2009
Moderator
JohnRPollard's Avatar
I somehow missed this thread back when it was posted. I just now noticed the title and thought "Good grief, don't we have another thread going on this topic already!"
Living aboard - and sex
P.S. Glad to hear it got sorted out.
JohnRPollard is offline
post #29 of 31 Old 03-12-2009
Sea Dweeb
RanAweigh's Avatar
Not sure but think maybe different squealing. Not accompanied by panting.
RanAweigh is offline
post #30 of 31 Old 03-12-2009
Somewhat Senior Member
mgmhead's Avatar
Did you check the power steering fluid?
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
Funny noise wumhenry Gear & Maintenance 38 05-25-2008 02:38 AM
Leading Sail Control Lines Aft Sue & Larry Gear and Maintenance Articles 0 08-11-2003 08:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
The Balance of Hull and Sails Steve Colgate Seamanship Articles 0 05-25-2000 08:00 PM
The Balance of Hull and Sails Steve Colgate Buying a Boat Articles 0 05-25-2000 08:00 PM
