01-02-2009
But that's not the best way to do it
You could use your current 1-2-Both switch, but that's not a great setup. It requires you to switch between banks when charging, or not, provides the possibility to drain your engine start battery inadvertently, etc.
A better way is to have a setup where you can turn your banks on and forget them, and then have a way to connect them in the event you need to start your engine from your house bank.
One way to do this is to have three simple on/off switches, one for the house, one for the engine start, and one to connect the two.
An alternative, and a better one I think, is to buy a Blue Sea switch panel that does exactly this. It's essentially the same thing as installing three on/off switches, but it's on one panel, the installation is a little easier, it's a bit more idiot-proof, and looks more slick. Here's a link to follow to see the item:
BLUE SEA 8080 PANEL DC PARALLEL IP - Marine.com, Blue Sea Systems - high quality marine electrical components
Dan Goldberg
