Problem with water coming up swing keel - Page 2 - SailNet Community
post #11 of 17 Old 01-03-2009
Here .. Pull this
The rubber stopper described by mercs is the best solution to your problem. There are several boats that use this method.
Sailormann is offline
post #12 of 17 Old 01-03-2009 Thread Starter
Thanks for all the help.
superiorvoyager is offline
post #13 of 17 Old 01-04-2009
Retired and happy
Leither's Avatar
Originally Posted by superiorvoyager View Post
How much difference does having the 800lb centerboard down actually make?.
The weight is not the important thing here. The centreboard decreases the tendency of the boat to drift to leeward and also changes the dynamics of the water flow under the boat. Both of these should contribute to improved handling, especially when pointing up.
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Leither is offline
post #14 of 17 Old 01-04-2009
Anything-Sailing Founder
ckgreenman's Avatar
Send a message via AIM to ckgreenman Send a message via MSN to ckgreenman Send a message via Yahoo to ckgreenman
The rubber stopper method is also commonly used in fountains to plug the bowl and run the power cord for the pump down through the pedestal.
Chris
S/V "The Jade Dragon"
1975 O'Day 25
Meet me at
Ignore Power = Currently Rebuilding
ckgreenman is offline
post #15 of 17 Old 01-04-2009
blt2ski's Avatar
How big is the tube? a lot of times rubber stoppers like Chris talked about, ie ones for fountains can be found pre cut with a hole from the mold. In your case, one that is drilled and cut by yourself, will work find, but in fountain situation, the premolded ones would be better vs making your own.
Most of the of the ones made for a fountain, are in the 3/4-1" diam in size. I would imagine that the hole for a CB wire is a bit smaller. But could be wrong here.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #16 of 17 Old 01-04-2009
CrazyRu's Avatar
Is it possible to place a winch on cabin top outside? Just extend the tube all way up through the top, and seal everything around the centerboard.
On my boat line for a board exits at cabin top. Inside tube looks like just a post, a handle.
CrazyRu is offline
post #17 of 17 Old 01-04-2009 Thread Starter
The pipe is about 2" Couldn't extend the pipe up as it would block the companionway door. In the spring I will try the stopper idea.
Encapsulated or Bolt On Keel? aasault Boat Review and Purchase Forum 51 03-26-2017 11:16 PM
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 17 07-30-2014 09:23 AM
Wing, fin, or bulb...what are the trade offs? langousta Gear & Maintenance 17 09-17-2008 04:54 PM
Winged Keels Pros & Cons OldGlory Boat Review and Purchase Forum 13 04-09-2002 05:51 PM
Swing Keel Dilemma SailNet Gear and Maintenance Articles 0 07-12-2001 08:00 PM
