Deck Core replacement - Page 4 - SailNet Community
post #31 of 60 Old 01-12-2009
Yes, but ease of working with it may more than make up for the price difference.
sailingdog is offline
post #32 of 60 Old 01-12-2009 Thread Starter
I don't discuss my member
zz4gta's Avatar
Not sure I follow. How much different is it going to be working with a plastic/foam core as opposed to plywood?
Merit 25 # 764 "Audrey"
zz4gta is offline
post #33 of 60 Old 01-12-2009
Balsa and Plywood don't bend—foam does, at least Airex does, Divinylcell less so. Most cabin tops aren't flat, so some curves are needed. IIRC, ContourKore balsa is pre-cut with kerfs in it so it can be somewhat more flexible than plain balsa would be.
post #34 of 60 Old 01-12-2009
Not just a member
Deck core
Trevor,
Like I told the guy in the other thread. I have over 15 year professional experience with these type of repairs. your boat is not very far from me. Give me a call at my shop:
Motovation Cycles & Accessories 301-472-1811. (Let them know when you call it is about my boat, They screen my calls from all of the telemarketers).I will be glad to have a look at it with you and get a game plan togther. I am sure we can swap some labor back and forth between our boats!
Dan
"Wind Wing"
Piewiet 850 / Dutch Flyer 28
Solomons, MD
Chesapeake Bay
"For the truth is that I already know as much about my fate as I need to know. The day will come when I will die. So the only matter of consequence before me is what I do with my allotted time. I can remain on shore, paralyzed with fear, or I can raise my sails and dip and soar with the breeze."
Richard Bode
-- from First You Have to Row a Little Boat
motovationcycles is offline
post #35 of 60 Old 01-12-2009
chucklesR's Avatar
Ditto on the labor Trevor.
I got a bottom to do and a locker to re-floor and re-glass.
It's always easier to measure twice when there are two people.
chucklesR is offline
post #36 of 60 Old 01-12-2009
donhaller's Avatar
That goes three times Trevor. Dan and ChucklesR, I'd be glad to help out with any of your boat chores. This will help me learn to do the work on my own boat.
Send me a PM when you need some help!
Chesapeake Beach, MD
C&C 25 MKI, Hull No. 039
donhaller is offline
post #37 of 60 Old 01-12-2009
Capnblu's Avatar
Too bad you guys don't live in BC. Try re-fitting a Tayana 42 with two artifical hips, on your own.
Why, why, why?
I Don't Know! I Don't Know!
Capnblu is offline
post #38 of 60 Old 01-13-2009 Thread Starter
zz4gta's Avatar
Thanks for all the offers of help, I'm reading over the requirements for the fillers and resins now. Trying to decide what's the best to use. I'll probably use the West systems, but not exactly sure of everything I'll need. I've been reading their website.
Originally Posted by motovationcycles View Post
Trevor,
Thanks for the offer Dan, I'm actually going down to the boat this weekend. Helping a friend move on friday, and sailing on saturday. Do you work on saturday? BTW I'm more than happy to help out others on their boats, and have connections to a machine shop if you need some strange parts. I'm a certified automotive machinist.
zz4gta is offline
post #39 of 60 Old 01-13-2009
Not just a member
Saturday
My shop is open From 9:00am to 3:00pm Saturday. Give me a call I Will come over and take a look. By the Way I went sailing yesterday. Tried out my "Victoria" remote control Sailboat my wife bought me for Christmas.
Dan
"Wind Wing"
Solomons, MD
Chesapeake Bay
Richard Bode
post #40 of 60 Old 01-13-2009
material
The contour-core balsa works great for curved surfaces. Just remember to fill the kerfs before applying. FWIW you can also bend ply over curves that aren't too radical--just lay up 2-3 of thinner sheets to get the requisite thickness instead of one thick sheet. You could also kerf yourself or apply in smaller squares. Another couple of thoughts for you... if you are using the West epoxy, the gudgeon bros (West system) people are great resources if you need some advice on the project--just give them a call. Also if you do end up doing it overhead you could do it sections. Just be sure to prep properly and overlap layers of glass. You might also think about using stainless/monel staples to fasten the inside cloth layers to the core and not have to worry about grinding off or removal.
Steve
idontwantanaccount is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
