Deck Core replacement - Page 6 - SailNet Community
post #51 of 60 Old 01-16-2009
Here .. Pull this
Well - you sound like you and your posse are ready to take on a big project so I'll wish you well. A couple of suggestions...
Don't pull the entire underside ot the deck off at one time. The boat will flex and you'll be epoxying a few bends and twists into the hull that shouldn't be there. Do it a small section at a time.
Think about using an alternate method. Cut 2 1/2 inch longitudinal channels out of the existing underside. Lay in a 3/4" stringer (wood/foam/carbon fibre/whatever) and then cover the stringer with several layers of roving. Once you have a complete structure of stringers, finish it off with some trnasverese ribbing done the same way. Then core between the stringers - use Airex. Cover everything with a bit of roving.
Remember NOT to use balsa in areas where hardware will pierce the deck. It is not strong enough from a compression standpoint. Use plywood. Make epoxy plugs on each hole.
Good Luck - Post Pics !!
Sailormann is offline
post #52 of 60 Old 01-16-2009
Wish I never found SN!
SimonV's Avatar
I am just glad I have a dry deck, I would have messed (EDIT BY CD) it up. Good luck and keep us informed.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #53 of 60 Old 01-16-2009 Thread Starter
I don't discuss my member
zz4gta's Avatar
I plan to document this repair the best I can to help others considering it's a pretty common problem. I got my bags packed for the weekend, going sailing saturday, and dropping the mast when we get her back in the slip. Also going to clean her out, and ready for the start on Feb 8th.
Sailormann, thanks for the tips!
Merit 25 # 764 "Audrey"
zz4gta is offline
post #54 of 60 Old 01-16-2009
This is very good advice.
This is more work, but probably a better choice in the long run.
Make the sections where the hardware comes through the deck solid glass that is tapered to meet the cored areas so you don't get a hard transition line if you can avoid it. Solid glass is a much better solution than pads of plywood, since the plywood can rot.
sailingdog is offline
post #55 of 60 Old 01-16-2009
Makes sense, wood rottens.
popeyeforearm is offline
post #56 of 60 Old 01-23-2009 Thread Starter
zz4gta's Avatar
One last question on materials, I'm looking at picking up the following and wanted to know what else I was missing. Please feel free to chime in.
750361
Epoxy Resin 105-B 10.3 Lbs. $68.99 $68.99
This item is on sale. - Our Regular Price: $74.99 - You are saving: $6.00
750364
Fast Hardener 205-B 2.3 Lbs. $30.99 $30.99
750408
Colloidal Silica 406-7 0.8 Lbs. $17.99 $17.99
751507
Episize 9oz. Glass Tape 733 4.4 Lbs. $90.99 $90.99
Subtotal: $208.96
zz4gta is offline
post #57 of 60 Old 01-23-2009
what else?
Buy the dispenser pumps for the epoxy--well worth the cost. Also, I have always thought West episize fiberglass was overpriced, its much cheaper to buy a few feet off of a roll and to cut your own strips. Just make sure the cloth (esp. mat or cloth/mat composites) are compatible with epoxy. Last time I think I bought cloth from raka, but there are numerous sources if you search for them.
Steve
idontwantanaccount is offline
post #58 of 60 Old 02-28-2009
core repair photos???? please post your progress
Please take images and post em here of the process. I (we) would like to see how this works out. I need to do the same.
thanks, Chris
(myblueheaven@att.net)
Myblueheaven is offline
post #59 of 60 Old 02-28-2009
Gary M's Avatar
I have done this on fairly small sections, no more than maybe a foot square. I used wax paper over 1/4" plywood propped up with flexible wooden pieces to first hold the coring in place then the two layers of glass. I will be doing 4 more small spots as soon as it is warm enough.
Worked fine, no real issues but I would be nervous about a large area. Start small and see how it goes.
Good Luck
Gary
Gary M is offline
post #60 of 60 Old 03-03-2009 Thread Starter
zz4gta's Avatar
I have two peices in place now. I do have photos but won't be able to upload them until tomorrow. I'll be down this weekend to continue the work. I may only repair about a foot in front of the chain plates this season, and complete the work next winter. We'll see how this weekend goes.
zz4gta is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
