01-10-2009
you may want to look into a product called teak guard. I've used it as have some of the other boats onn the dock and I've been real impressed with it. You'll need to sand off the old varnish but it should be the last time you have to sand it. The process is very simple...sand off the old, use the "striper", coat with 3 or 4 thin layers of teak guard. Over time you will need to apply the striper and reapply teak guard but it won't require sanding.
s/v Puggin Along
1988 Catalina 30
Washington, NC
