Old 01-10-2009
Hunter
SVSnap is on a distinguished road
Blown out RHI glue
I know it's not a sailboat... but some of you sailors must have had rhib problems at some point right?
Boat: 12' center console Aquapro RHIB
Motor: 25hp honda 4 stroke
Year: 2001
Construction: PVC tubes, Aluminum Hull
Problem: Glue failure at transom-tube joints
Stbd-
Port-
I bought it used for cheap a couple years ago and have had lots of fun with it, should I:
a. Try to clean that glue off (googone??) and reglue with "Colle Klebstoff Glue - Groupe ZODIAC 2"?
b. Try to get it professionally redone (I'm cheap tho...)?
c. Pull the Honda off the back and try to put it on a little whaler or similar (tough retrofit...lots of $$$)?
all input appreciated. I'm going back to scrubbing the deck on the real boat....
Thanks!
Hunter
"Benvolere"
Catalina 30 Tall Rig
Alameda, CA
Old 01-10-2009
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Your first source of info should be the Aquapro website dealing with repairs, but since they have no technical information at all I'd use deal with their people.
You need to know exactly what it's made of and how it was glued and follow the specific recommendations for fixing it. They specify that they sell tubes made of hydropolymer and hypalon.
I couldn't find anything on what they call hypopolymer assuming yours are not Hypalon.
Old 01-10-2009
Hunter
Ya, that's true, I should def give them a call. I talked to a dealer (not sure if he was officially affiliated with them, just that he sold their stuff) back when I lived in San Fran. He told me PVC construction and sold me this Colle Klebstoff glue...
I'll call them up on Monday and see what they officially suggest.
Thanks man.
Thanks!
Hunter
"Benvolere"
Alameda, CA
Old 01-12-2009
If they can't give you a good solution, there's always 5200.
need glue & cement expert xort Gear & Maintenance 49 01-17-2009 05:04 PM
Glue removal question patrickbwells Gear & Maintenance 11 03-28-2007 09:56 AM
Gorilla Glue on a boat? jr438234606 Gear & Maintenance 14 08-11-2006 08:52 AM
Blown Away James Baldwin Seamanship Articles 0 09-13-2004 08:00 PM
Blown Balmar? z1nonlyone General Discussion (sailing related) 3 01-30-2003 12:25 AM
