Old 01-10-2009
donhaller's Avatar
donhaller is on a distinguished road
What's the best tool for cutting through the cockpit floor?
I got to get down to the boat today for a longer period of time, and started removing stuff to get started on clean-up and winter projects to get it ready for spring. I just bought the boat in November and because of the holidays really haven't had a chance to spend much quality time down there with her.
Anyhow today I removed the teak cockpit floor grate and vacuumed out the junk that was under there and discovered I have a bigger problem than I first thought. I knew it was soft, but the entire floor will need re-coring.
Someone in the past has already drilled and filled numerous locations with no success. They and even tried to provide more support by bonding a piece of plywood on the underside of the flooring with some glass cloth. But that has delaminated over time too. I really should remove that piece of plywood as well, since it doing nothing but adding more weight and little or no support now.
I understand the whole process pretty clearly and have decided to absolutely go at it from the top since the surface is so messed up to begin with. I'm just not sure what is the best tool to cut it with. I have a pneumatic disc cut-off tool and air compressor I can use, or a dremel tool, also air grinder etc, but thought maybe one of those cordless mini-circular saws might work good too. I'd like to get as close to the outside edges of the cockpit floor as possible, and thought that might get me closer. I'm not sure though. Any suggestions for cutting it out?
Here is a large photo of the crappy floor.
Chesapeake Beach, MD
C&C 25 MKI, Hull No. 039
Old 01-10-2009
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Check cutting access hole for ideas. Esp. since you want to get right up to the sides, a Fein Multimaster or equivalent might be your best bet.
Jim
s/v Abracadabra
1976 Pearson P30
Old 01-10-2009
GaryHLucas is on a distinguished road
Just a thought for you. Unlike a deck you could easily build the floor up a 1/2" or more without a problem. So instead of doing all that cutting and fixing, why not just glass the hell out of it? If you just cut woven roving to fit the well and laid it down in epoxy maybe five or six layers thick you'd have a nonskid patttern looking floor in no time.
Old 01-10-2009
donhaller's Avatar
I have considered that option, but there will still remain voids and moisture in the existing core. Perhaps that doesn't matter in the grand scheme of things.
Thanks for the idea.
Old 01-10-2009
paulk's Avatar
paulk is on a distinguished road
I like using a dremel or similar bitted tool. It enables you to get closer to the edges and to do a neater job, especially around scuppers and the like. A bigger tool will create problems getting in there and seeing what you are doing. Since it's cored, you only want to go through the top layer anyway. A smaller tool will give you better depth control as well. You only need to go through the top 1/8" (maybe) of fiberglass. Once you've pried that off, the rotted core should come up with a screwdriver or putty knife. You can bed new core on the old inside layer, and then layer in the new cockpit floor layer. (You probably already know this.) The extra plywood support piece they added in probably won't be necessary once the repair is made and everything is stuck back together properly. We repaired our cabin top from the inside, and getting the resin, core and fiberglass to stay UP was a major Chinese fire drill. Working with gravity is a good idea when you can do it. To avoid crazing or point failure later, it will probably be a good idea to grind down the edge along where you cut so as to have better adhesion and to increase the contact area between the new and old fiberglass.
Old 01-10-2009
all these confusing ropes
dohenyboy is on a distinguished road
Fein saw
Old 01-10-2009
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
I've used one of these
With a rotozip DC1 bit.
John USYacht 27 "Cora Lee"
Old 01-10-2009
twcook
Guest
Posts: n/a
In a similar project, I had good luck with the mini-circular saw attachment for a Rotozip tool. The rotozip itself worked ok but it's hard to cut a straight line (if you care), but the circular saw made for a neat cut with a fairly thin kerf. A cordless mini circular saw would probably work fine too.
Old 01-10-2009
donhaller's Avatar
That would be easier since I already own the angled die grinder. I would have to lug the air compressor down to the marina, but I suspected I might have to do that anyway some time or the other. I thought about putting a mini saw blade in the die grinder, but I'm not sure they make one for it.
Old 01-10-2009
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
If you don't have to go all the way to the outside edge, I would use a rotozip or simular tool with a small router base that would act as a guide shoe, that way you end up with a equal ledger around the cockpit floor to work with
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Best tool for cutting fiberglass cockpit seat costaricanwannabe Gear & Maintenance 18 10-02-2007 07:04 PM
The Cruising Cockpit Sue & Larry Buying a Boat Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Gear and Maintenance Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Cruising Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Her Sailnet Articles 0 07-08-2003 08:00 PM
