cell phone signal amplifier - Page 4 - SailNet Community
post #31 of 36 Old 01-18-2009
Anything-Sailing Founder
ckgreenman's Avatar
Send a message via AIM to ckgreenman Send a message via MSN to ckgreenman Send a message via Yahoo to ckgreenman
You'd be surprised what they can do nowadays to disguise cell towers. I've seen some that, besides the perfectly straight trunk, you couldn't distinguish from a palm tree. Now lack o users, well there's not much you can do about that.
Chris
S/V "The Jade Dragon"
1975 O'Day 25
Meet me at
Ignore Power = Currently Rebuilding
ckgreenman is offline
post #32 of 36 Old 02-26-2009
Earth Skater eCommerce
Lightbulb Cell Phone Signal Boosters
You should contact UnwiredSignal.com directly to inquire about Cell Phone Signal Boosters and the effectiveness of these devices.
I prefer Unwired Signal (unwiredsignal.com) because they specialize in fixing cell phone signals, and not only do they have affordable pricing (better than Tiger Direct), but also free customer service. Call them and give them the exact details of your cell phone signal booster situation and they will recommend exactly the right product for you.
Here is the link to their signal booster category FYI:
unwiredsignal.com/?c=132&cn=Building+Cellular+Signal+Boosters]Wilson Building Amplifiers & Repeaters
Save your time and money - eCommerce web hosting with free web design and complete setup $49.95 / mo - Visit
today!
earthskater is offline
post #33 of 36 Old 02-26-2009
celenoglu's Avatar
An external antenna that can be attached to your cell phone might work. If your unit has an antenna jack (generally used for car systems) use an outside antenna. I have done it on my boat, the transmission is much smoother.
The unit is connected to a coaxial cable and the antenna is a wire of 12 inches connected to the middle wire of tye coaxial.
celenoglu is offline
post #34 of 36 Old 02-26-2009
There's actually a whole new type of amplifier coming out for boating use. unwiredsignal and companies like them typically use Wilson amplifiers designed for cars. The environment of a boat is a lot different especially without the nice ground plane of the metal roof. If you really want to examine those types of amps, a quick search will find places that have them at much lower prices - check out primecellular.com as one example.
If you want to find out about the issues with amplifying cellular signals on boats, check out:
ActiveCaptain - Going Mobile - Mobile Phones Series
That article will be updated when new products are released. Sign up for the newsletter by registering on the site for free. There's a lot of talk about Cell Ranger in that article. I wouldn't get that yet either. While it is about half the cost of the Wilson amps and does work pretty well, there are marine versions of it just about to come out. It's worth waiting until Spring.
The article referenced above gives some real world examples about why adding just a cellular antenna (no amp) will often reduce the signal being put out by your phone. There is almost no good in adding just an external antenna.
JeffreySiegel is offline
post #35 of 36 Old 10-26-2009
Talking Repeaters do Work...
You can go to google and find all kinds of repeater systems, but you need to be careful, do your research.
I found that [/B]Wilson Electronics[/B] makes only signal boosting products for all kinds of applications. While on Wilson's website I found this company called UnwiredSignal.com. They have a repeater that is the 801201M Its a repeater system for a vessel 35' to 75' in length its a repeater-booster for your cell phone signal.
I also found a very helpful page on their site [/B]Wilson VS The Competition[/B] You should check it out...
I personally know it will work, I purchased the bigger kit for vessels over 75' the 801245 MM cost more than the other one, but definately worth it. It increases the existing signal and works for my air card and cell phones. This is extreemly helpful when you need to monitor the weather online and keep in contact with family.
Hope this helped.
s.i.t.
itsoc is offline
post #36 of 36 Old 10-28-2009
SV Déjàlà
braidmike's Avatar
While there are many great ideas here, I have a 'try this first' low tech solution for the laptop: when a signal is 'almost' there for my laptop (good in the cockpit or on deck, but I'd rather sit below) I use a six foot USB extension cord for my air card. Usually I can move it somewhere around where I'm sitting and get a much better signal. I have a hanging oil lamp over the table, which seems just about right! It's low tech, but it works in my marina...
braidmike is offline
Cell Phone amplifier - mast antenna Joseph Hardin Gear & Maintenance 10 10-13-2011 03:36 PM
