01-15-2009
Spectra, vectran and dyneema based lines can all be stronger than their equivalent diameter stainless steel wire rope, with about the same amount of stretch. However, it does have the problem that they're not as chafe resistant as stainless steel wire rope. Provided you've made sure all the sheaves and such are smooth and clean, so as not to chafe the line, I'm sure it'd work quite well as a swing keel pennant. One thing to consider is how you are going to terminate the line so that it is protected from chafe at the attachment point.
