Tank Tender - SailNet Community
post #1 of 2 Old 09-22-2002 Thread Starter
Tank Tender
Own a 38'' CC Irwin with two water tanks holding a total of 180 gallons. 90 per tank.
There are no gauges on either tank to tell me how much water is in each tank at any given time. With my sailing plans how much water I am holding during the sail will be important.
I have been researching installing gauges and based on the set up of the Irwin and where the tanks are located I would have to remove the sole to acess the tanks. I really don''t want to do that if I don''t have to. I do believe that there is a portion of the tank(s) that can be accessed once one twists and turns into the spaces below the setees.
I have gotten information about a product named the Tank Tender which seems like something that might be the answer.
Has anyone installed this product and if so your opinion?
Does anyone have other suggestions.
Thanks
Ray
wannasail is offline
post #2 of 2 Old 09-22-2002
Tank Tender
Overall, we are very happy with our TankTender. In ten years of intermittent use, the unit only required one service call, and turnaround price and time were reasonable.
The simplicity of the unit and the good materials it is made from contribute to its longevity. The only tedious things to consider in the installation is the construction of a calibration table, and not to kink the semi-rigid tubing used to measure the depth of the liquid in the tank.
Since most integral water tanks are not shaped like rectangles, a "inches of depth" reading only becomes meaningful when you measure actual water in tank vs. the depth reading and affix the table nearby. Ditto for the waste and diesel tanks.
Putting kinks into the semi-rigid plastic tubing is pretty easy. Leaks or stoppages can result, either of which will make readings suspect. So think hard about how to route the tubing (that is unless TankTender has found a new and better way to do it).
The simplicity of the unit and the lack of energy required to run it make it very attractive for me. However, be sure to brief people on how to use it, as over-pressurizing the lines can lead to damage. I''d buy it again.
Cheers! Constantin
Constantin is offline
Fuel tank problems Lusk Gear & Maintenance 18 01-23-2007 06:17 PM
Building a head tank Irwin32 Gear & Maintenance 6 11-05-2006 01:24 AM
Holding or fuel tank jeanneau beneteau Myblueheaven Living Aboard 0 02-28-2005 10:35 AM
holding or fuel tank Jeanneau Beneteau Myblueheaven Cruising & Liveaboard Forum 0 02-28-2005 10:34 AM
removing orig water tank zeilfanaat Gear & Maintenance 6 04-12-2004 07:26 AM
