“Too good to be true” windlass deal? - SailNet Community
post #1 of 8 Old 01-16-2009 Thread Starter
MisterBilge's Avatar
I’ve got the boat (28’ S2) in the back yard for a re-fit b4 heading off on a coastal cruising adventure next spring (not working on it today as it’s 22 below zero!) and even though I’m a great believer in the K.I.S.S. principle, it appears they can’t give away the Lewmar V1 windlass cheap enough.
List for $2300, I’ve found it for as low as a few hundred bucks. I’ve got a lot of homework to do before pulling the trigger, but this is sure looking good to a guy born in the Truman administration who’ll be doing a lot of anchoring whilst single handing. Talk to me guys.
MisterBilge is offline
post #2 of 8 Old 01-16-2009
Is it new? Then go for it, if you can afford to power it and install a battery and remote charger that it is more likely than not going to require. Personally, on a boat your size, I would recommend going with a manual windlass.
sailingdog is offline
post #3 of 8 Old 01-16-2009
At currently advertised discount prices, the V1 looks like a very good deal.
Be sure to install it with healthy-sized wire/cable. The manual isn't very helpful...doesn't even give amperage draw stats...and the table given is confusing (why combine boat size and wire-run lengths, when only wire-run length is important?). I'd use wire a size or two larger than shown in this rather crummy table.
JMO,
Bill
btrayfors is offline
post #4 of 8 Old 01-17-2009
We got a Lofrans Royal Horizontal Windlass for our 28' cutter (12,000# displacement)...
Royal Horizontal Manual Windlass
We paid a little under $700 for it after doing a lot of searching. I wouldn't even consider an electric on a 27' boat. Too much hassle and definitely unreliable compared to a manual.
"There's a wind in my sails that protects and prevails." - "Six Months in a Leaky Boat", Split Enz
sander06 is offline
post #5 of 8 Old 01-17-2009
I was pleasantly suprised at the relative ease of raising our 45 lb anchor on 10mm chain with a manual windlass. I was sure I wanted an electric when we bought the boat.
With this 'bargain' windlass, are you getting what you pay for?
xort is offline
post #6 of 8 Old 01-17-2009
Ignoring Trolls in 2009
TxLnghrn's Avatar
Looks like Lewmar is closing out a couple of windlass lines. $600 for a V1 super compact.
V1 Super Compact Stainless Steel Anchor Windlass
S/V Anything Goes
1987 Pearson 31-2
Hull #15
TxLnghrn is offline
post #7 of 8 Old 01-18-2009
Probably consolidating after they bought out Simpson-Lawrence. The windlass I use is an Anchorman manual windlass, which they discontinued just before I bought mine IIRC. It's a nice windlass, for a manual one... and works quite well on my boat.
post #8 of 8 Old 01-18-2009
MB,
I'm going to offer my 2 cents and suggest that you consider going with an electric windlass, rather than a manual. I offer 3 reasons for this recommendation.
1. You indicate that you will be doing a lot of single-handed sailing. The most dangerous time for any sailor is when he leaves the safety of his cockpit and goes out on deck. Going up to the bow to handle the anchor in rough weather can be a nightmare. With an electric windlass you can safely deploy and retrieve your anchor without having to go forward.
2. Given the size of the boat (27 ft.) and your cruising area, it is unlikely that you will be using all chain. You will most likely use a smaller-sized anchor and line, with a 10 ft, chain rode. You won't need a heavy-duty windlass to raise this combination. Muscle power will work just fine if you choose not to install a windlass.
3. As your engine will most likely be running when you engage your electric windlass, you'll put minimal stress on your battery bank.
I have owned two boats (25 and 35 ft.) on which I mounted electric windlasses. Both vessels had just starting and house batteries and I never suffered any electrical issues.
Finally, my present boat, a Hunter 30, has no place to install a windlass, so I must use muscle power. As I single hand most of the time, I do not enjoy having to go up to the bow to do the anchoring. I feel quite vulnerable out there. I would love to be able to install an electric windlass so I could just pick my spot, drop the hook, let out enough scope, and set the anchor, all at the push of a button. Seems like a smart and safe way to do things.
P.S. I'm also a Truman-era baby.
AlanBrown is offline
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 130 08-30-2013 11:51 AM
Good Deal?? CherylannJohn Chartering 3 12-31-2004 09:35 PM
Quiten Sailing good deal wakai Boat Review and Purchase Forum 3 11-27-2003 10:48 AM
Best way to sell???? Sailmale General Discussion (sailing related) 2 05-13-2003 06:22 PM
Ingredients for a Good Leader John Rousmaniere Seamanship Articles 0 08-27-2001 08:00 PM
