01-19-2009
There are three types of hinge adjustments on the Lewmars.
one is as explained above, a hex screw at the end of each hinge, there was an older model that had hex screws on the side, and the third, used in the latches, is a small hole, that looks like a hex screw, but this one is on the side of a round face nut.
You need to pull the cover off, to expose this nut, then use a sharp object or a thin scre driver to rotate the nut, wich will increase hinge friction.
The latches are the third type above
Hope it helps
Alex
