Old 01-17-2009
Alden44GER is on a distinguished road
Shaft 'bushing' worn out (Alden 44)
Hi
I've got a problem with the shaft 'bushing' (correct term?) in the middle section of my Alden 44 prop shaft.
To prevent the long shaft from swinging the shaft sits in a kind of greased shaft bushing made by Dogde. The upper half of this 30 year old thing is detachable and has got a grease cup on top of it. The inner bush of these two half shells are made of a soft metal (similar to lead). Unfortunately, the upper shell is worn out and the whole thing needs to be replaced. I really tried hard but I couldn't find such a (simple and nearly perfect) thing on the Internet (probably since English isn't my mother tongue and I don't even know the name for it).
Does anyone know what I am talking about? If yes, does anyone know where I can get hold of such a thing?
The shaft started to make a noise at the end of our summer crossing. I avoided higher RPM when the noise got unpleasant. Eventually, I had to stop using the prop. I removed the top half and cut two narrow channels it the soft material, put two matching pieces of flax packing in the grooves and by means of pressing grease into the hollow space between the shaft and the bushing it went as smoothly as new. Anyways, I think I’d rather have a new whatever-it-is-called-thing.
Thanks,
Luis
Alden44
Old 01-17-2009
merc2dogs is on a distinguished road
It's normally called a carrier bearing over here,
most likely the soft metal is babbit.
depends a lot on how the thing is built, if there are two thin steel backed shells, (half circle shaped) with the babbit inside, you may be able to locate an automotive counterpart.
If the babbit is a very thick chunk of with a simple cage of some other metal to mount it, you can cast in new babbit. It melts easily low temp on a simple gas burner,(kitchen or camp stove give plenty of heat)
It's easy to do, but wouldn't recommend something critical as a first project.
Ken.
Old 01-17-2009
Thanks for the information, Ken.
Alden44
Old 01-17-2009
Leither's Avatar
Retired and happy
Leither is on a distinguished road
A similar alloy to Babbit metal is known as white metal in the UK and used for the same purpose. The term "white metal" actually covers a range of alloys, but if you are using the term in the context of bearings, then people will know what you are talking about.
Good luck
Stuart
Leith (rhymes with teeth) is the port of the City of Edinburgh in Scotland. A Leither is someone who comes from that area.
I must go down to the sea again, to the lonely sea and the sky - I left my shoes and socks there, I wonder if they're dry?
Old 01-19-2009
Good luck
Stuart
____________________
Hi Stuart,
Thanks for the information.
Luis
Alden44
Old 01-19-2009
rayncyn51 is on a distinguished road
Most shops that restore or repair antique gasolinge engines can reproduce babbit bearings from the old one.
Are we there yet?
Old 01-19-2009
funsailthekeys is on a distinguished road
Yea, what they said.
Old 01-19-2009
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
It is not a Cutlass Bearing?
Pacific Seacraft 34 ljbabin Gear & Maintenance 10 06-06-2009 11:18 AM
Propeller Shaft "Flaking" tcase10 Gear & Maintenance 6 08-02-2008 12:02 PM
Marina Lawsuit/ Looking for help;advise Lawson911 General Discussion (sailing related) 67 06-23-2008 11:10 PM
A Worn Shaft Log Tom Wood Gear and Maintenance Articles 0 10-06-1999 08:00 PM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 08:00 PM
