Old 01-18-2009
hertfordnc is on a distinguished road
Yanmar 2QM20 tranmission- substitutions?
I damaged my transmission. Ultimately I guess I will rebuild it but I've found several good deals on used gear boxes for other Yanmar engines- specifically a 2GM, YSM12
Even if it were not the ideal replacement, my sailing is pretty tame compared to what this boat was made for so if the trans bolts in and works it should meet my needs for a season.
Are they interchangeable? Bolt pattern? shaft coupling?
In over my head?
First Boat, a well-equipped 1977 Camper Nicholson 31
What is all this stuff and how does it work?
Old 01-19-2009
Rockter will become famous soon enough
Hert :
I suspect they are the same. It is not in the manufacturers interest to have a big inventory of gearboxes.
Yanmar 2QM20 Exhaust part - help hertfordnc Gear & Maintenance 19 12-13-2010 06:07 PM
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Yanmar Problem Solved... Warren M. Gear & Maintenance 1 09-01-2008 09:39 PM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
ATF or SAE ? Yanmar 4JH2E / Trans: KM4A TAK Gear & Maintenance 4 11-05-2007 10:34 PM
