Old 01-19-2009
trantor12020's Avatar
trantor12020 is on a distinguished road
Sticky rubber on Bino
Sometime ago, I report the rubber parts on my Tesco binoculars becomes sticky. Since then, I found no solution to reverse or remove the sticky rubber. So as last ditch effort prior to throwning it away I wrap the bino in Glad Wrap (thin plastic sheets for wrapping food stuff) and top it off with some sticky tape to hold it all in place. Glad (pun' intended) to say it works just fine. My fingers are nolonger sticky from using the bino.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 01-19-2009
dsmylie is on a distinguished road
If you have not done so already you might try Armorall cleaner, just dont get it on the optics.
Old 01-19-2009
retclt's Avatar
Roadkillibus Texanis
retclt will become famous soon enough retclt will become famous soon enough
. . . . . . . and classy looking too.
Bob T
"I cannot not sail" - E. B. White
Beneteau first 456 port rubber seal replacement jwmoir Gear & Maintenance 4 09-20-2009 08:55 AM
I'm itchy, sticky and happy merttan Gear & Maintenance 4 07-27-2008 06:03 AM
Rubber = Galvanic Corrosion? sailboy21 Gear & Maintenance 10 02-09-2008 07:50 PM
Sticky Tachometer maboyer S2 3 11-20-2007 07:52 AM
Remove Rubber marks on hull? Variant_530 Gear & Maintenance 2 07-11-2002 02:05 PM
