Westerbeke 33, can it be rebuilt? - Page 3 - SailNet Community
post #21 of 22 Old 03-16-2009
If, otoh, you're the adventurous sort . . .
. . . (or stupid?) you might consider messing with it.
Admittedly, you might want to check back with me after a year or more my actually having run the thing, but I just put new rings, a head gasket, and a head cleaned up by my local machine shop (glass-beaded, resurfaced, valves ground) into my Yanmar 2QM15. Runs like a champ. (And what a feeling of accomplishment!)
And I've dis- & re-assembled the injector pump & injectors for a good cleaning. In fact, I used better rods & pistons from a 2nd engine (it has a bad head) that was given to me. And combined the best of the rod bearings from the two. A real Frankenstein's monster, but hey -- the price is more-like-right than that quoted for either a professional rebuild or a new engine.
Now, I'm not going offshore, nor am I running excursions, nor patrolling the Columbia bar, etc, so I'm thinking I have the latitude to try some DIY approaches to things. (Apparently, I have more time than I can cope with, as well!) It's nice that the engine is small enough so working on it has been (almost) a pleasure, and given that I'm trying only to improve a few of the tolerances in a 30-year-old chugger, I figured I could hardly miss. (At this point, it appears that I may have been right.)
Whatever, it sure feels good to have some sense of what's going on in there . . .
broggerp is offline
post #22 of 22 Old 03-16-2009
Valiente's Avatar
You do have that option. My rebuilt Atomic 4 has a new crankset, but the head and the gears and a few other bits and pieces were scavenged from two other salvaged blocks.
For the offshore diesel, though, I'm going "pro-with-instruction-options".
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 11 04-19-2012 10:45 AM
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 10:10 AM
Westerbeke 27 - Diesel Consumption Rate craigtoo Gear & Maintenance 28 03-11-2008 09:18 PM
Westerbeke opinion. maxim_rfeld Gear & Maintenance 3 04-23-2003 05:15 PM
Where do I Find Rebuilt Westerbeke Engines? mmf1029 Gear & Maintenance 0 07-07-2001 04:17 AM
