01-22-2009
I'll disagree with SD ( dangerous, I know ) I would use cetol, I might go with two base coats and a min of 3 clear.
If you do mare it up, it will most likely be in the top coats, which then can be touched up with just a light sanding and a coat of clear
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
