Pocket screws in boat building? - Page 2 - SailNet Community
post #11 of 22 Old 01-23-2009
I don't believe she is talking about using it for structural items, like bulkheads... Denise is smarter than that. I believe she may be intending to make a table or other furnishings for her boat with pocket screws. There should be no problem with doing that IMHO.
Originally Posted by kaluvic View Post
So it "toe-nailing" with a self tapping screw!
It looks to have a raised thread like a drywall screw.
It seems to be less about the design of the screw, and more about the jig that makes it easy to drill the counter sink hole.
I would think the question about using this to attach bulk heads would be more about using this method than this particular screw.
As for me those screws have no place on a boat...the idea of "toe-nailing" has its place...if used for attaching bulk heads I'd us a lot of screws, SS or bronze.
However, I would prefer other more robust methods that will be easier to plug the holes.
sailingdog is offline
post #12 of 22 Old 01-23-2009
kaluvic's Avatar
That sounds OK...but for the money and work I'd use dowels or those football looking wafers.
James S
S/V Arctic Lady
kaluvic is offline
post #13 of 22 Old 01-23-2009
blue collar cruiser
soulesailor's Avatar
In certain applications pocket screws are superior to biscuits. I agree it is more about the pocket itself and the application of use rather than the actual screw. If the SS pocket screws were way expensive I would just use a similar sized SS pan head screw.
who is staring at the sea is already sailing a little
soulesailor is offline
post #14 of 22 Old 01-23-2009
kaluvic's Avatar
Biscuits....that’s the word I was looking for!
I agree soulsailor, screws may have some advantage, no clamps for one and having a real mechanical fixing that does not rely 100% on the glue could be worth while advantages.
James S
S/V Arctic Lady
kaluvic is offline
post #15 of 22 Old 01-23-2009
JimMcGee's Avatar
There are lots of woodworking joints because there are lots of applications. I like the Kreg setup for cabinet work. Once you're used to their jigs you can go pretty fast.
Biscuit joints, especially if you use two offset biscuits are surprisingly strong. But it all depends on what you're trying to do, what kind of wood you're using and what kind of environment it will live in.
Fine Woodworking did a stress test of woodworking joints a while back. You can find it on their web sites as a PDF. The results are pretty interesting if you enjoy wood butchering. taunton.com/finewoodworking/ToolGuide/ToolGuidePDF.aspx?id=31926
I say use whatever tool / joint will get the job done.
Jim McGee
94 C22 Island Time
95 C30 Goin' Coastal
Maple Shade, NJ
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #16 of 22 Old 01-23-2009 Thread Starter
One of None
deniseO30's Avatar
I confess! bought one of the K jigs today! first try gave me a perfectly drilled pocket and i joined to pieces of Marine ply in a corner joint. I was impressed!
My last project!
deniseO30 is offline
post #17 of 22 Old 01-23-2009
ronspiker's Avatar
As with any question the answer is 'It Depends'. It depends on what your use is. I do alot of woodworking, cabinets and furniture, so if you are making something like that then yes pocket screws work very well. I would also use a polyurethane glue like Gorilla glue also unless you plan on taking it apart. Another option if you are joining corners is to use dowels and glue, or countersink screws. I would only use screws if you are using SOLID wood. If you use screws in plywood it will delaminate, maybe not at first but over time it will split between the plys.
ronspiker is offline
post #18 of 22 Old 01-23-2009
Stainles Pocket Screws can be obtained here:
Google: McFeely's Squaredrive Scews
Mistercraft is offline
post #19 of 22 Old 01-24-2009
poopdeckpappy's Avatar
Right on denise030
before you get to into whatever you're building, look into Hi low screws if you are going to be working with plys and softwoods
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #20 of 22 Old 01-24-2009
I have used the Kreg jig on several small projects and have been very pleased. Used in conjunction with epoxy sealed/glued wood and then filling the hole with a thickened epoxy I have what appears to be a bullet proof joint. 2 years latter there are no signs of problems. David
dsmylie is offline
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 05:46 PM
Trailering? Pick a Boat Bruce Caldwell Cruising Articles 0 07-22-2004 08:00 PM
Understanding the Racing Rules, Part Three Dean Brenner Racing Articles 0 09-09-2002 08:00 PM
Spinnaker Takedown Basics Dean Brenner Racing Articles 0 04-28-2002 08:00 PM
The New Racing Rules Dobbs Davis Racing Articles 0 04-04-2001 08:00 PM
