01-25-2009
The design if the exhaust system is more important to you when the engine is off and water is not being driven out of the system by the exhaust gases.
Unlike a power boat a sailboat can still be underway when the engine is off, it heels, has waves hitting the transom in a following sea and water can be forced into the system and into the engine particularly if there is residual water in the system. A loop that rises as high a possible or an expansion chamber can overcome this.
A waterlock also acts as a muffler, but more importantly it is at the lowest point in the system between the engine and the loop or gooseneck/expansion chamber at the transom or wherever the exhaust exits above the waterline. It is a collection point for water left in the system when the engine stops and is sized not so much by the engine but also by the volume of the pipes connected either side of it.
It is possible for water to siphon in exhaust systems, to prevent this at siphon- break is utilised between the heat exchanger and raw water injection point, the siphon-break should be raised above the waterline to be effective.
Water getting into the engine is bad, really bad, very tiny amounts cause corrosion of valves and cylinder wall, small amounts can cause a hydro-locking when it gets into a cylinder and when the engine is cranked will prevent the piston from reaching TDC, if the engine cranks it can bend con-rods and you are into a re-build or replacement of the engine.
Atomic 4's and Palmer P60's are low compression gasoline engines, in the order of 8:1 - 9:1, diesel engines on the other hand are compression ignition engines and have compression ratios of 20:1 or more, so in some respects the importance of good exhaust design is more important for a diesel.
I hope this helps.
