01-24-2009
In our experience cockpit cushions are in the way when we're actually sailing.. ours only come out when we're moored/anchored (or on a long motoring leg) and about to reward ourselves with a cool one...
If you ran a traveler track across the cockpit your cushions would probably still work ok when you're not underway under sail. Alternatively you could cut the cushions to fit fore and aft of the traveler itself.
Another possibility would be to move the traveler aft, go to end-boom sheeting and open up more cockpit space that way.
If you really want to ramp up the performance and be able to more easily and effectively adapt to changing wind conditions, a good traveler setup is the way to go. But it must also be easily adjustable under all conditions, and that requirement means it won't be real cheap....
1984 Fast/Nicholson 345
