01-25-2009
Be aware that three-strand docklines are often better if you need to tie up to wooden pilings, as the double braids tend to bet picked apart by the splinters more than does three-strand laid lines.
Most docklines are usually nylon, mainly due to the stretch nylon has. Double braid nylon is a bit easier to handle, and doesn't have the tendency to hockle, like three-strand laid lines do. If you don't need to tie up to wooden pilings, get double braid nylon for your docklines.
Also, I highly recommend using woven cloth chafe protection, rather than hose, as one major cause of failure in docklines is from internal heat due to frictiion. Hose-type chafe guards prevent water from getting to the rope and soaking, lubricating and cooling it—woven fabric ones generally do not have this problem.
