01-26-2009
Installing compass in steering pedestal
I have a Danforth Constellation compass that is mounted in a binnacle on a steering pedestal. Unfortunately the prior owner made a change since the compass is loose in the steering pedestal. The compass is attached to a stainless steel cannister that fits over the top of the steering pedestal. The problem is the stainless steel canister is not bolted/screwed to the base of the steering pedestal so the entire unit can be picked up and removed from the steering column, which is not necessarily and issue unless the boat broaches, then the compass (and stainless canister) fall off the steering pedestal.
ffice  ffice" /> >>
What is the normal mounting arrangement for attaching a compass to a steering pedestal that is mounted in a canister? If this is to vague let me know and I will get some photos.
