3M Water Filtration - Page 2 - SailNet Community
post #11 of 16 Old 01-29-2009
several manufacturers do make plumbed UV sterilization units... not cheap though.
Originally Posted by labatt View Post
Cuz they don't make a plumbed unit.
sailingdog is offline
post #12 of 16 Old 01-29-2009
Maine Sail's Avatar
MaineSail - I was hoping to get a .2 micron unit, which is what this 3M unit is for a lower price than a SeaGull. From what I understand, there is the possibility of contaminated water down south, and I don't want to take the risk. SD - I agree on doing the galley faucet only.
That filter is a MUCH better deal than a SeaGull. I still personally would want to treat with a treatment to kill the bacteria and sequentially filter or pre-filter to the .2 micron filter with a sediment filter in the 2-5 micron range. My SeaGull plugged up very quickly. I could not find a price on the 3M cartridge?? If you are going to third worl countries a .2 micron is not a bad idea but filters of any kind should not sit without flow for long perids of time. Excercising your water filters is a must.
One thing to be concious of is the lingo use in the filtration industry. The nominal rating is .2 micron but that does not mean it catches 100% of all .2 micron sized particulate and they will pass larger particles than .2 micron. Though not a reall big deal I wish there were more disclosure about nominal ratings and what % of particles larger than .2 it actually passes? Is it 1%, 2% or 5%..
I still like a cap full of bleach or tank treatment every now and then just to be sure. If you don't do this the bacteria can begin to grow and then really plug up your filters fast. A filter does nothing to prevent bacterial growth inside the tanks or lines and it only removes what is there. Don't let it get there is my whole point. If your don't let bacteria grow or kill it as you add water to the tanks then you and your filtration system will be better off..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 16 Old 01-29-2009
just don't use bleach regularly if you have aluminum tanks...or you'll pay for it.
post #14 of 16 Old 01-29-2009
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by tommays View Post
I take care of a pharmacutical DI water system and if you knock down the water in steps like 5 / .5 / .2 the .2 last forever
Do you have specific recommendations? Inquiring minds want to know.
SVAuspicious is offline
post #15 of 16 Old 01-30-2009
tommays's Avatar
Well
I would have a small 5 micron setup to use on the hose you fill your tanks with as when we treat CLEAN city water this is were the bulk of the dirt comes from
No matter how clear your water LOOKS you will be supprised when you start changing filters how dirty they get
Now even with a state of the art system with a BIG UV unit we still sanitize the system once a week with bleach BUT we also flush it out completely as there is a chlorinated water exposure and bladder cancer risk
With in the boat i would only try and filter the drinking water and would try and use a 1 or .5 to try and protect the final .2 micron most of the units will also remove the chlorine and take care of that issue
As mainsail says you need to keep the water moving even if you run the tap and put the water back into the tank
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #16 of 16 Old 04-22-2009
Abysmally Stupid
It installs between the output of the pump and the fixtures .
This may be a stupid question but;
I am thinking about adding a filter to my Catalina 400.
Should one install the filter directly after the pump ( I have a small accumulator tank just after the filter) or just before the cold water faucet in the Galley?
1. Just after pump
This would mean that both hot and cold water would be filtered and water for both head faucets, showers and cockpit shower water would be filtered.
2. In the cold water line just before the galley faucet
This would mean that only the cold water in the galley faucet would be filtered and filtration would occur just before the faucet.
I am thinking option number two as the amount of filtered gallons would be reduced and the filter would last longer. I am also thinging that it would be enough to have drinkable, filtered water in the galley only (not heads)
Another question - there is limited space to install the filter - can the filter be mounted horizontally or does it have to mount vertically?
Cheers
jorgenl is offline
What's your biggest bonehead move sailing? CharlieCobra Seamanship & Navigation 613 07-19-2016 08:10 PM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 04:50 PM
Understanding Tidal Currents Jim Sexton Her Sailnet Articles 0 08-05-2003 08:00 PM
