01-31-2009
Street Pilot
Thanks Lagniappe for posting this as well.
Which version of the software are you using? Does the wiring still allow the Street Pilot to be powered? I am contemplating doing the same as a back up and wondered if this set up will work with the Garmin NUVI as well. If not, which Street Pilot are you using? Currently we have the laptop with a different charting program called, Chartview Odyssey, which is older and I want to upgrade to one that can use all the new free electronic charts...connected to a Standard Horizon small screen plotter via a Serial cable with a usb adapter on the end. I'd like to get a new chart program for the laptop as well as the right interfaces to do what you did.
TIA,
121Guy
