Shaft Seal Failure - What do you do? - Page 3 - SailNet Community
post #21 of 25 Old 01-30-2009
the pointy end is the bow
erps's Avatar
Also, after the shaft seal is installed in the proper position I use a black permanent magic-marker to note the point where the aft end of rubber bellows joins the stern tube and the forward edge of SS seal ring is positioned on the shaft. A quick look at the shaft seal is part of my daily engine maintenance routine and with these marks I can quickly see if either the rubber bellows or the SS seal ring has moved.
Excellent idea. I think the bellows are supposed to be replaced periodically too.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #22 of 25 Old 01-30-2009
Courtney the Dancer
jrd22's Avatar
Right you are Erps, I replaced the PSS seal and bellows this year during the refit and they told me every 8 years or so. I figure I'll do it every 4 years, pres. election makes it easy to remember, that's when I have the septic tank pumped too . I like the idea of the two piece collar Maine, thanks.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #23 of 25 Old 01-30-2009
ArgleBargle's Avatar
interesting thread. when i burped my previous dripless shaft seal i was surprised how much water came in. i dont know if my bilge pump could have kept up with that rate.
a related request for opinions on what you could do if the rubber seals/gaskets on a saildrive failed (apart from heading very quickly to the nearest haul out) - assuming for argument's sake the alarm between the diaphragms didnt go off or it was due, however unlikely, to the saildrive striking bottom. i cant think of anything obvious that would help, but perhaps i dont know my ass from a hole in the hull.
ArgleBargle is offline
post #24 of 25 Old 01-31-2009
philsboat's Avatar
Tell me if this is a silly idea.Cut a section of motorcycle tube long enough to go from the shaft outlet tube to the shaft.Clamp the end at the outlet then roll up the excess to be used in an emergency(tape it back so it can't get caught in rotating shaft).If you have a bad leak just roll it out and clamp to shaft.Will Try it on my boat this summer.
My stuffing box nut came loose once and I was suprised how much water came in!
Phil
philsboat is offline
post #25 of 25 Old 01-31-2009
Lynger1
Hi this is the first ting i have in my spare parts box on board new gland packing.like other said water Will be manageable
you can replace this in the water
my prop shaft run has a seal at the exit after the main back bearing
Prepare gland stuffing and replace it fast with pump running you Will be able to do this and this problem will be fix
lynger1 is offline
PSS shaft seal Windborn Gear & Maintenance 26 02-01-2009 10:10 PM
Jeanneau Sun Kiss 47 - shaft seal freeheel999 Gear & Maintenance 0 11-21-2007 04:02 PM
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 11:03 AM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 05:41 PM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 08:00 PM
