Old 02-02-2009
Alden44GER is on a distinguished road
winterizing watermaker
Hi again,
how do you guys winterize your watermakers? My boat is in the water, the PUR Survivor is filled with a biocide/water mixture and it's getting chilly now. (The water temperature is about 3° C. yet)
Regards, Luis
Alden44
Old 02-02-2009
You probably should call the manufacturer and ask them, or look in the owner's manual and see what it says.
Old 02-02-2009
billyruffn's Avatar
billyruffn will become famous soon enough
SD is correct about seeking manufacturer advice. I offer the comments below as a "generic approach". I developed it because I have a desal system that's engineered from generic components and the "manufacturer - assembler" of the system was located in a warm climate and chose not to deal with the subject in the Xerox-ed owner's manual I have.
I winterize the system by first "pickeling" the membrane and then removing the pressure vessel with the membrane and biocide inside. I carefully cap the fittings to keep the biocide in the pressure vessel to keep the biocide from spilling out and then take it home -- storing it horizontally in a warm space. The key is not to let any part of the membrane dry out during the winter.
Winterizing the rest of the unit is pretty simple. The filters are removed and drained (new filters are installed on recommissioning) and the pumps and lines are winterized with non-toxic antifreeze. I make sure that on recommissioning all the anitfreeze is flushed from the system before installing the pressure vessel and membrane. This can make a mess, especially when you flush the HP pump, so you want to make preparations to contain the flushing water. To flush the system on recommissioning, use clean seawater if you can. If not, use distilled water. Don't use tap water as it may contain chlorine which will harm the membrane.
It's my understanding that the biocides in the membrane will hold up for only six months, so it's possible that the membrane might need cleaning when you recommission the system.
I've found keeping up with the desal maintenance to be too much of a hassle unless we're in a live-aboard cruising mode where we are not often at a dock and/or water is expensive. When we're just doing seasonal cruising in NE, water is free and not hard to find, so I keep the system off line. This means that I may need to replace the membrane when we go cruising again, but that's a price to pay for not having to recommission, maintain and decommission the system every summer.
Old 02-02-2009
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
SK told me to just pump in potable antifreeze.
Call your manufacturer
Old 02-02-2009
billyruffn's Avatar
Gee, I've read that membranes are pretty sensitive to chemicals????????????????
Old 02-02-2009
billy
this was from the SK Watermaker technician. hope he's right!
Old 02-02-2009
badsanta is on a distinguished road
I heard the same, use the same pink antifreeze for potable water lines. Do not do this under pressure. open the pressure valves needle valves ET all and run it through do not do this at 800psi. This is supposed to be good for a year. Biocide does NOT protect from freezing. Also if you use booze the ETOH will dissolve the o rings
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
Old 02-03-2009
Thanks for your help ... I like the idea of removing the pressure cylinder and storing it. I was a bit concerned about winterizing it with a chemical, too.
On the other hand it sounds so nice and easy to simply flush it with potable antifreeze.
I will check the boat tomorrow and then decide.
Thanks,
Luis
Alden44
pur watermaker installation/engine intake rrgane Gear & Maintenance 6 05-06-2008 10:11 AM
Watermaker "Pickled" Pamlicotraveler Gear & Maintenance 6 10-21-2006 07:07 AM
