Old 02-03-2009
tommays's Avatar
This old mast & rivets and screws
Well
After 28 years my mast is really needing some paint so i am glad i got and early start as it is really a lot of work removing all the hardware
The PO of the boat was a bit on the hack side so to no supprise many of the cam cleats were mounted with sheet metal screws
BUT in heating and PB blasting all the OEM 10-24 screws many did not make it and will have to be changed to 12-24 as the mast is to thin for heli-coils and some parts cant be moved
The big supprise in all this is every SS sheetmetal screw came out perfect go figure
The 3/16 SS rivets all drilled out perfect with no signs of hole dammage
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-03-2009
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
How will you paint the mast? What paint will you use?
Old 02-03-2009
Tom, what mast do you have?
Why don't you anodize it instead?
Old 02-03-2009
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
Imron 2 part paint is relatively easy to work with if you follow the directions closely (don't ask why I stress that)
Just takes time to do all the steps.
Biggest hassle is painting when there is no wind to kick up dust
Old 02-03-2009
tommays's Avatar
I dont dont know of a place around here than can anodize a 35' section BUT i will look a bit and it is a bit on the wild side driving around with the 35' section on my trucks roof rack And i think it would be hard because they also sprayed the inside of the mast
The mast is kind of beat up and i feel paint will give the best looking end result IF i was buying a NEW mast it would be clear anodize for sure
I will be using perfection becasue it seems to have the best priming system and my friend did his at home last year at it has held up very good so far
1 . Vinal-Lux primewash
2. epxoy prime coat
3. perfection top coat
I also use to build and paint bicycles using the PPG version of Imron and own good SATA spraying EQU and saftey gear
I also have a indoor 60' room with a fume hood to draw the fumes out of the temp dust tent
Tommays
Northport NY
Old 02-03-2009
tommays's Avatar
I have been looking and the EPA seems to have chased all the anodizeing places to New Jersey
Tommays
Northport NY
Old 02-03-2009
dakuehn's Avatar
dakuehn is on a distinguished road
Tom,
Are you going to go back with screws instead of the 3/16 stainless rivets?
Old 02-03-2009
tommays's Avatar
The rivets worked perfect and were easy to remove they will be replaced with new rivets
A few parts that used screws will be getting rivets BUT the parts that are to thick OR the sheeve retaining plates will have to stick with screws and will go to 12-24 with tef-gel as required
Tommays
Northport NY
Old 02-03-2009
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
I painted my mast with Perfection and I'm very happy with the results. 2 seasons on it so far and no dings in the paint.
Before painting the mast, I sandblasted it. It's a real PITA but I think it will help keep the paint on it longer. If you sandblast, you have to spray the vinyl-lux on within an hour after blasting. I also added flattening agent to the paint because I didn't want reflection off the mast when I'm trying to trim sails. Besides if you dull the finish on a gloss surface it will look bad, on my mast you can't tell.
John USYacht 27 "Cora Lee"
Old 02-03-2009
dakuehn's Avatar
I asked about the rivets because I have the same situation as yourself, but have had a difficult time finding a Air Rivet Gun for rent that can handle 3/16 SS. As a result, I was considering tapping and going back with 1/4" screws--thanks
Mast Bedding Compound J36ZT Gear & Maintenance 6 05-19-2008 04:57 PM
Self tapping screws in the mast. paul77 Gear & Maintenance 29 11-23-2007 10:25 PM
Sail Control Duke 7184 Gear & Maintenance 3 06-13-2007 08:23 PM
pop rivets or machine screws? groundhog Gear & Maintenance 7 06-01-2007 08:03 AM
If you were going to install mast steps... RobHoman Gear & Maintenance 2 01-28-2002 06:40 AM
