Old 02-03-2009
scottyt is on a distinguished road
yanmar motor mount replacement idea
okay i read a thread somewhere about someone replacing their motor mounts, they did not use yanmar mounts. on the replacements they used the studs where too short, so they used rubber vibration sheet to bump up the height a little. Raw Materials > Rubber > Sheets and Strips > Rubber,Buna-N,1/2 In Thick,2 x 36 In : Grainger Industrial Supply
so i thought why not replace the rubber in the mount with it. a few problems but not many mostly it is not going to be glued to the mount like the stock rubber. but hey we own things called bolts.
here is my idea, cut scrape what ever the old rubber out. then replace it with stacked layers of the rubber to the right height. now to hold it in place use a pin ( pictured in red below ) welded to the upper steel part, which fits in tight holes drilled in the rubber. these pins basicly align and center the rubber to the mount. then use bolts thru tightly drilled holes thru the rubber, with the hole thru the upper metal mount drilled larger to give room to viberate with touching the bolt. it would require stacks of rubber on top too with plates for the bolt heads to bear on.
what does every one think, it works out that all four mounts can be rebuilt for under 50 bucks vrs over a 100 per stock mount.
okay pics first a stock mount
now a paint drawing of my idea
black stock steel parts ( sort of )
gray rubber sheet
red alignment pins
orange bolts
blue backing plate
Old 02-03-2009
now i know my drawing does not look just like the yanmar but you should get the idea, i drew it to be simple to look at and understand it
Old 02-03-2009
funsailthekeys is on a distinguished road
They don't cost that much to go thru all that trouble.
Old 02-03-2009
well in the current market my income has come down about 50 %, 400 bucks is a weeks income
Old 02-03-2009
$400.00
I was thinking more along the lines of the damage that might happen if they didn't work out. Just to haul my boat out for anything is close to $600.00.Not that it was a bad idea.
Old 02-03-2009
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
yanmar engine mounts
the yanmar mounts are designed to cut down on vibration transmitted to the hull. when they design them they have to figure in the weight of the engine & transmission, also the thrust from the propellor. it would be hard for an individual to duplicate this, it is better to get the correct mounts.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
Old 02-03-2009
k1vsk will become famous soon enough
All too often, people tend to take the cheap route and find it to be a false economy resulting in an even greater expense later. Yo do it properly, the mounts have different specs depending on which side of the engine they are intended - how would anyone replicate that?
More important, the question arises - what difference does it make and what are the consequences of doing it wrong?
Old 02-03-2009
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
The Yanmar mounts are also different for the front and back of the motor.
Irwin Citation 34
Old 02-03-2009
Not just a member
motovationcycles is on a distinguished road
mounts
Not worth it, get the factory mounts. Pretty cheap in the scheme of sailing things. Also the bolts will transmit vibrations from the motor to the engine bed. I have seen this tried before. There are always mounts on E-bay for cheap.
Dan
"Wind Wing"
Piewiet 850 / Dutch Flyer 28
Solomons, MD
Chesapeake Bay
"For the truth is that I already know as much about my fate as I need to know. The day will come when I will die. So the only matter of consequence before me is what I do with my allotted time. I can remain on shore, paralyzed with fear, or I can raise my sails and dip and soar with the breeze."
Richard Bode
-- from First You Have to Row a Little Boat
Old 02-03-2009
Omatako's Avatar
Omatako will become famous soon enough
Yep, I agree. The propellor is commonly believed to push the boat but in fact the propellor pushes the engine/gearbox which in turn pushes the boat.
The connection between the engine and the boat (the mountings) gets a whole lot more energy through it than is normally understood. If the mobility (or lack thereof) of the mounting is compromised, the whole drive line integrity goes with it and then you get vibrations (from both the bolt contact as well as the shaft misalignment), water leaks, stress cracks, etc.
No, I reckon the money you save by making up Heath-Robinson mountings will be burned away very quickly in additional maintenance. Get the real thing.
Arthur C. Clarke
Yanmar Problem Solved... Warren M. Gear & Maintenance 1 09-01-2008 09:39 PM
Yanmar Engine Mount Specifications HenryTully Gear & Maintenance 4 06-27-2008 10:20 AM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
LED Replacement Bulbs Shack Gear & Maintenance 8 02-13-2007 08:10 PM
HobieOne Sail has holes... replacement? buzzard86 General Discussion (sailing related) 4 01-25-2007 10:32 PM
