Old 02-04-2009
bljones has a spectacular aura about bljones has a spectacular aura about
do you plan to hinge your door, or stowable, like a large dropboard?
  #12
Old 02-04-2009
SailingFlorida's Avatar
SailingFlorida is on a distinguished road
The door is stow able the drop kind. With the warmth of the sun today the cetol dried fast and i was able to place the finished door in to cover her for the night. Ill take a picture of the completed project when im done. I want to add some new brass screws for the original door scoops / handles, it going to look tits when its done.
Love the paint job on this tanzer but then you have to buy 3 different colors and non ablative isnt cheap. All dark red is going to look sweet!
  #13
Old 02-04-2009
Whoa. You plan to paint the whole hull with anti-fouling bottom paint? BTW, now that you have fastened the dropboards together into one large board, do you have a plan to stow it? You may find it is less cumbersome if the dropboards remained separate, rather than being screwed together into one large door.
  #14
Old 02-05-2009
Having separate dropboards rather than a single giant dropboard also makes it easier to swap one out to ventilate the boat when at anchor and such.
  #15
Old 02-05-2009
Melrna's Avatar
Crazy Woman Boat Driver
Melrna will become famous soon enough
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
Sailing Florida.. You will love the Tanzer 22. It was my first boat. I raced her for 4 years and won many a race with her. Be careful how you had weight on her and not move the CG of the boat. Those tiles while look pretty could had weight where you don't want one. I had a 9 Hp Volvo outboard that never worked. Hence I learned fast how to sail her in and out of slips. My point is she is real easy to sail. Keep the hatch boards separate if it is not too late. Trust me on this one. If you have the swing keel version check the pin and wire rope carefully before you launch her.
Melissa Renee
Rhapsody in Blue
  #16
Old 02-06-2009
Too late on the drop boards ive found a place to stow the door while sailing so that wont be a problem. As far as the weight I dont think that the tile will add that much weight to the boat to be a problem. Add it is even bulkhead evening ea side out and the counter top and table evening ea other out.
  #17
Old 02-06-2009
How high up do i want to go on the paint? I figured if i did the whole hull then im covered.
  #18
Old 02-19-2009
Here is the door finished:
inside
outside
Also I took some picture outside how far up on the boat do i need to go non ablative? What other kind of paint do i use for the rest up to the rubrail?
  #19
Old 02-19-2009
sailortjk1's Avatar
looks like you already have an existing water line, just follow that. Unless you think you need to modify it for some reason.
Lots of Topsides Paint out there. Thats like asking what anchor I should carry. Your going to have to do some research. A talk with your local chandler will help. Awlgrip, Awlcraft, are a couple but they can be expensive and difficult to use for the DYI.
This link might help, it has some tips on DIY Topside Painting.
Sailing World - The Do-It-Yourself Topside Paint Job
Courtney is My Hero
  #20
Old 02-19-2009
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
All the black gets ablative bottom paint.
You may post attachments
You may edit your posts
tanzer 25 Dave Wright Tanzer 12 04-13-2009 12:57 PM
Any good Tanzer 22’s for sale?????? jsamuels Boat Review and Purchase Forum 6 09-13-2006 11:07 PM
Tanzer vs Cal prrthead Boat Review and Purchase Forum 0 03-11-2002 10:11 AM
SEO by vBSEO 3.6.1
