Acetone use - Page 2 - SailNet Community
post #11 of 15 Old 02-06-2009 Thread Starter
I'm not following you, Sailaway. I sanded the bottom pretty well, and I'm down to a coat of hard paint. But there is a thin film of dust on the boat from all the sanding. If I rub my hand across the bottom it comes away the color of the paint. It would seem necessary to at least clean that stuff off of the bottom before trying to paint. I wouldn't think the paint would stick to that. You don't say anything about cleaning the bottom with any sort of liquid, which suggests painting over the remaining dust. Am I getting that right? And I thought a primer would be necessary if nothing is known about the hard paint to make sure that the ablative would stick to it.
drynoc is offline
post #12 of 15 Old 02-07-2009
Don't use acetone. It flashes to quick and leaves sanding residue on the hull. Make sure you have a good 80 grit sand on the hull, and use either the paint company's suggested thinner, or a solvent such as Xylene. It is generic, and can be purchased anywhere. Use clean rags, and wipe in the same direction. Wipe down the hull twice. After it has dried, you are ready to apply whatever product you are going to use.
Bob Harris
Pettit Marine Paint
bdwr1962 is offline
post #13 of 15 Old 02-07-2009 Thread Starter
Thanks again
I checked this morning for answers, and there weren't any new ones. The weather is 55 degrees here today - a day not to be missed in this area in February. So I went ahead - and cleaned it with MEK. It seems to have worked well; the hull feels dry and is dust free. It's epoxy repairs tomorrow, another cleaning job, and then paint time.
drynoc is offline
post #14 of 15 Old 02-07-2009
bljones's Avatar
two words: tack cloth.
bljones is offline
post #15 of 15 Old 02-08-2009 Thread Starter
Tack cloth
Five words: excellent idea.
drynoc is offline
Lead keel coating Soutie Gear & Maintenance 16 08-07-2015 02:09 PM
Acetone or Mineral spirits? Finallybuyingaboat Gear & Maintenance 11 04-30-2008 01:52 PM
Acetone, bleach, lamp oil. Where/how to stow? Mary51 Cruising & Liveaboard Forum 20 02-06-2008 12:33 PM
Drying Wet Deck Core with Acetone saurav16 Gear & Maintenance 11 10-08-2007 01:06 PM
202 Solvent vs. Acetone Timm40 Gear & Maintenance 8 03-01-2004 02:44 PM
