Old 02-05-2009
drynoc is on a distinguished road
Acetone use
I've been through the search system, and don't see this discussed in detail. I've sanded the bottom of my 35 footer, and it is my understanding that the next step is to clean it with acetone. But how is this done? Put some in a bucket and dip a wrag into it? Pour a little on a wrag? Does the wrag need to be soaked, or just damp? At the end, either way, you will end up with a bucket full of acetone with paint dust in it. How does one dispose of that mess?
Old 02-05-2009
mkirk51 is on a distinguished road
I'm not sure what your plan for paint is, but I stripped my 28 Oday down to gelcoat and used Interprotect 2000E followed by VC17. They recommended Fiberglass Solvent Wash 202 as a final cleaning. I don't remember where I read it but I used cheap paper towels. Lots and lots. The cheaper ones won't have printing (ink) on them. Apply a little solvent, wipe down, throw away, wipe with a fresh dry one. When done, apply clean water to the surface. If it beads up at all, you're not done. There's good info on their website.
It might have been overkill to spend the money on their solvent wash. Acetone might be just as effective, and certainly cheaper. But I figured when I'm spending that much time and money, I'm gonna follow the directions to the letter. Nothing would tick me off more than to have hauled the boat and seen the paint peeling off. And that didn't happen.
Old 02-05-2009
r.furborough is on a distinguished road
Dampen rag with acetone directly from can, wipe surface of boat until acetone in rag almost dry, refold rag and apply more acetone to clean area of rag and repeat until rag dirty then use new rag. Wear gloves as it will take the natural oils from your skin.
Acetone will evaporate, so only paint or fiberglass residue in rag is a problem. Dispose of rag safely or if not too dirty I wash them and re-use.
Do not put acetone in an open container, apart from it evaporating quickly is is highly flammable.
Old 02-05-2009
Maine Sail's Avatar
generally a
Generally a dewaxer should be used with multiple rags. About 40-50 white terry cloth rags (Sam's Club) should de-wax and clean a boat your size. The solvent softens the mold wax then the rag removes it. If you re-wipe with that rag without turning it or folding it you'll just re-apply what you took of. If your boats bottom paint had been peeling then it's a good sign the hull was never properly de-waxed and cleaned before sanding and painting. Sanding a hull that has not been properly de-waxed only makes matters worse because it drives the wax into the surface scratches even deeper..
Either Pettit Dewaxer 95 or Interlux 202 are a good choice Acetone is a great solvent but not so much for ensuring a hull has been properly de-waxed....
Photo courtesy of West marine
Photo Courtesy of Jamestown Distributors
______
-Maine Sail / CS-36T
Old 02-05-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
I would not use Acetone as it is nasty stuff. Go ahead and use Acetone if you really dis-like your liver as it is absorbed though the skin and cause liver damage.
Use a DE-waxer or simple paint thiner. Wear rubber gloves. Heres a link that might help you!
http://www.yachtpaint.com/USA/hotlin...paintguide.pdf
Never Forgotten
Old 02-05-2009
tommays's Avatar
I find the thin gloves allow solvent through to easy so I would just wear the heavy rubbber gloves as i have never found any of the MSDS sheets to have much good news
And in my old and wiser age i also wear a respirator a whole lot more even when i can only smell it a bit
Dont make a haz-mat mess with buckets of solvent and at least around here if you roll out old paint on paper and let it dry it is legal waste at that point
If not then we have many STOP place to allow a homeowner to dispose of things correctly
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-05-2009
Rockter will become famous soon enough
It is a superb solvent.
It tends to remove paintwork a wee bit, so be careful.
A wee bit in folded rag works well, renew it regularly from a wee bottle.
I would not use a bucket as it evaporates like crazy and it is expensive
Old 02-06-2009
Thanks, guys
I'll do a little more research on solvents other than acetone to see if any of them might work better. My boat is not down to bare fiberglass - the existing paint is in good shape, and there are only two coats on it. My plan is to clean the bottom, put on a pigmented primer coat, and then a couple of coats of ablative.
Old 02-06-2009
SOUNDBOUNDER's Avatar
SOUNDBOUNDER is on a distinguished road
Before you use acetone, wipe the bottom down with damp or wet rags. I have even used a Scotch-Brite pad.
This will remove a lot of the excess residue without having to waste acetone.
Once it has dried, then you can use the acetone.
It used to be common to hose down the bottom after sanding it. But that makes a big mess on the ground, and is usually frowned upon these days.
Good Luck!!!
Old 02-06-2009
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
I doubt that you'll need either the acetone or the primer if I read your above post correctly. If you're using the same ablative paint as is currently on the boat, I'd advise a light scuff sanding, along with repairing any damages present, and then a straight application of your bottom paint. The acetone will tend to soften the paint already on the hull and, if recommended by the manufacturer, I'd use it. If not recommended specifically, I would not as it sounds like you've a good base to adhere to.
Wm. F. Buckley, Jr.
Acetone or Mineral spirits? Finallybuyingaboat Gear & Maintenance 11 04-30-2008 01:52 PM
Acetone, bleach, lamp oil. Where/how to stow? Mary51 Cruising & Liveaboard Forum 20 02-06-2008 12:33 PM
Drying Wet Deck Core with Acetone saurav16 Gear & Maintenance 11 10-08-2007 01:06 PM
Lead keel coating Soutie Gear & Maintenance 15 08-01-2006 11:31 PM
202 Solvent vs. Acetone Timm40 Gear & Maintenance 8 03-01-2004 02:44 PM
