Old 02-07-2009
rjg23's Avatar
SoME Sailor
rjg23 is on a distinguished road
Hardware through Head Liner
Replacing/adding hardware to the cabin top to lead lines to cockpit. Cabin has integrated/solid head liner. Options: 1) remove liner, install hardware, install new liner; 2) install hardware through liner; or 3) add your own here.
I'd prefer option 1 but concerned about disturbing the structural integrity that the liner provides (I'm assuming it does). Option 2 would certainly be easiest but concerned about how to make sure the hardware is supported from below with the liner in tact. PO attached present hardware by drilling oversized hole in liner and using washers only to back up the hardware to the cabin top. If I were to use a backing plate it seems that the liner would be pulled up creating depressions in those locations.
Any thoughts or advice would be appreciated.
Southern Cross 31
SoME
"If you are lucky to live by the sea, you are lucky enough"
Updating Your Head Sue & Larry Gear and Maintenance Articles 0 12-25-2002 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
Head Maintenance Blues Tom Wood Gear and Maintenance Articles 0 11-21-1999 07:00 PM
Head Maintenance Blues Tom Wood Her Sailnet Articles 0 11-21-1999 07:00 PM
