02-07-2009
We've had similar issues with growth on our prop. Painting the bronze with Micron CSC does cut the growth to a good degree, but the paint wears off the tips of the blades too fast, and the remaining paint ends up in pitting the bronze because of electrolytic action: not good. We've also found that there's less growth when the zincs on our strut aren't replaced... The greenery seems not to like the galvanic charge-- but this also eats up the bronze. I had thought to simply spray paint the prop and strut with the stuff they use for outboards, but it calls for a special metal primer undercoat (yellow, IIRC), to isolate the topcoat from the metal underneath. This is actually what you should use before applying the Micron CSC anyway, so that's what we plan to do this spring. Luckily, we read the label on the spray can before deciding not to buy it.
