03-09-2009
I just ordered two, based on using them on three different boats, since my friends have them. Since they're an ethernet bridge, there is no driver problem, since it uses the regular ethernet driver on your machine. One is going to be used to create a bridge at one of my client's offices and the other is destined for my boat.
It uses a web browser to configure the Nano Station 2. If you want information on the configuration process, click here.
Since there's no software to install, there are really NO CONFLICTS to worry about, regardless of what OS or machine you use. Totally compatible with any modern OS that can use a web browser and supports an ethernet card.
Originally Posted by winterbuoy
SD, you have one of these Nano things? Are they a hassle to set up and what else do you need? Went through so many usb internet crap, they all screw up.
