Wifi - Page 4 - SailNet Community
post #31 of 43 Old 03-23-2009
jarcher's Avatar
Yup, it's hard to compete with free
jarcher is offline
post #32 of 43 Old 04-30-2009
Smile WiFi Bridge
Sailingdog, forgive me cause I dont know that much about WiFI bridges but with the nanostation 2 it connectss to an existing WiFi access point say a distance away, gets an IP address and then relays the signal to another WiFi card on my computer?
So I configure it to WPA or what ever kind of signal I an trying to retrieve?
Thanks
Mark
fawcettm is offline
post #33 of 43 Old 04-30-2009
No. The NS2 is a WiFi to Ethernet bridge. Your computer would get the network communcations by its wired ethernet port. The NS2 converts the WiFi signal into a wired ethernet signal... you don't use the WiFi card on your computer at all.
I would recommend you read this WiFi primer that I wrote a few years back.
Thanks
Mark
sailingdog is offline
post #34 of 43 Old 05-01-2009
WiFi Bridge
Thanks, I read the primer, so really the bridge is acting like a high power wireless card. Sorry I couldnt understand why I would use an access point or setup my own wireless network to get wireless network, I am too used to using wireless or routers to setup a network for home. It never dawned on me to use it this way.
what distances are you getting with this configuration? and is it hard to setup for other locations when you are on the move? Do you find that there are alot of open networks? or do you pay alot?
thanks, this is helping, I went to a weather seminar last night expecting to learn how to predict weather, and it seems nowadays predicting means going to the internet.....thus wireless.....
Mark
fawcettm is offline
post #35 of 43 Old 05-01-2009
Yes, basically, it is a high-gain wifi card attached to a ethernet interface. [/quote]Sorry I couldnt understand why I would use an access point or setup my own wireless network to get wireless network, I am too used to using wireless or routers to setup a network for home. It never dawned on me to use it this way.
what distances are you getting with this configuration? [/quote]
I setup a terrestrial link, using the NS2s that is about 2.5 miles... but that is in a relatively rural setting, without much in the way of additional radio interference. The NS2 is designed for WAN WiFi links, and is specced to reach as far as 15 KM under the proper conditions.
Configuration of the NS2 takes a bit of getting used to, as it uses a web-based interface. However, one major advantage of the NS2 is that it avoids any driver configuration/stability issues, unlike many of the USB-based solutions. A second advantage is that it means you don't have to continually muck with the WiFi settings in your laptop either. Finally, it does have the advantage of being able to be hoisted a good way up the mast without the resulting signal losses or need for a booster USB cable that using a traditional amplified antenna or USB-based device would create.
Mark
From the war-driving I've done, I've found that open wireless networks are pretty common. Jiwire.com is a website that has a fairly large database of them. Personally, I'm against open WiFi networks, and see them as a security risk... which is why I wrote the WiFi security primer in the first place.
post #36 of 43 Old 05-01-2009
WiFi Bridge
This is getting alot clearer.....so I am sailing for the day, get to my next anchorage, haul the antenna up the mast. Does the antenna then see the available networks? I choose the open ones to connect to or go ashore and find out the local secured WEP or WPA keys and go back configure and I am off to the races?
Mark
fawcettm is offline
post #37 of 43 Old 05-01-2009
FawcettM—
If you configure the NS2 properly, you can have it automatically pick up open networks. However, if the networks are secured, you'll have to log into NS2 and configure it to match their security setup.
post #38 of 43 Old 05-01-2009
WiFi Bridge
Thanks this has been very helpful, now to go and buy one......have to see if they sell them in and around the Toronto area.
fawcettm is offline
post #39 of 43 Old 05-01-2009
Dog...I've come a long way in my understanding of the NS2/IP address operation thanks mostly to you and I may be wrong here, but in my limited experience, if you move away from the previous access point, the NS2 will not automatically pick a new access point and will revert to it's native 198.168.1.2 (IIRC) ip setting and, if that address is on a separate sub-net from your ethernet adapter, you will have to manually set your ethernet adapter to match the subnet in order to communicate with the NS2 screens. Then you can pick a new access point and go back to automatic re the ip addresses.
Have I passed the course yet ?
Bruce
"Solitude" Caliber 40
Ches Bay
bhcva is offline
post #40 of 43 Old 05-01-2009
Not quite.
It depends on how you have the NS2 configured. If you're using it with the SSID ANY and no security, it will attempt to associate itself with any available, open access point. If it manages to connect to the access point, it will attempt to get an IP address dynamically, and then use it. If it fails to get an IP address, it will probably go and self-assign an IP address. If you're going from harbor to harbor and using only open, unsecured access points, then it will not need to be reconfigured when you change harbors.
If you're using secured WiFi networks, and they're different, then you'll need to reconfigure the NS2 when you change locations.
BTW, be aware that regardless of whether you're on a secured WiFi network or not, you will probably want to use secure protocols for e-mail, web browsing, etc, as anyone on the WiFi network will be able to run a packet sniffer and grab your traffic pretty easily. E-mail, by default, generally sends the user name, password and mail contents in CLEARTEXT. That means anyone with a packet sniffer can find out your e-mail username, server, and password without much trouble. Most modern e-mail servers have some sort of encryption as an option, and I highly recommend it be used. Whether it is SSL-based encryption or TLS-based encryption or using an SSH tunnel... using encrypted tunnels for your e-mail is a good idea.
Bruce
WiFi on the Boat? Sailpilot Living Aboard 42 03-18-2012 10:37 AM
Boosting WiFi signal dsbentley Gear & Maintenance 20 01-22-2008 04:11 PM
WiFI and VOIP in the Caribbean wetdirt General Discussion (sailing related) 12 11-17-2007 05:40 PM
Wifi mallo Gear & Maintenance 3 03-21-2007 10:09 AM
