Old 02-10-2009
brianontheroad's Avatar
brianontheroad is on a distinguished road
Water Pump?
I need a new water pump! I'm replacing a lot of the old systems on board before we take off cruising in the spring and I want to put in a new water pump, we have two outlets, a third if I decide to hook up the shower. Sink in the head, sink in the galley and shower in the head. I'm not sold on the shower, I think I'll stick to a solar shower.....don't have to worry about the shower sump and don't really like taxing my fresh water supply all that much -- so unless the cost difference is negligible I'd like to stick to a simple pump for two outlets. The pump will be pretty close (within 6 - 8 feet) of both outlets. The original pump moves the water all the way back through to the hot water heater (one of the propane ones that likes to blow boats up) and I'm going to plumb straight to the sinks. Any thoughts on a particular brand that is fairly inexpensive and reliable? I will also be installing a whale gusher foot pump as a backup (might end up using it more than the electric pump while cruising)
Thoughts?
boat is 37 foot Chris Craft Apache
Thanks!
Brian
Old 02-10-2009
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
I've had good luck with Jabsco. Since you are doing the replacement, you may want to look into the new variable speed pumps. They are supposed to be much quiter than the older versions. Although we have never had problems with our pump, it is very loud.
Old 02-10-2009
camaraderie's Avatar
moderate?
You might also think about adding a small accumulator tank with the pump to cut down on thumping and cycling if you don't already have one.
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
What's your biggest bonehead move sailing? CharlieCobra Seamanship 421 09-26-2011 10:05 AM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
