10-04-2002
Oil Changer Pumps
I use a Big Boy Topsider and I''ve found it to be quite effective. The most important thing is that you run up the engine to operating temperature to get any particles up in the oil before you start to pump the oil out. Any pump will leave a little oil residue, but not enough to worry about. Feedback I''ve received from other people is that the inexpensive electric pumps (drill attachment for example) aren''t worth the money. Jabsco makes a good electric oil remover pump and it sells for about $130 as I recall.
