02-12-2009
Moderator
Originally Posted by cleepq
The gas to my stove on my Beneteau 311 (2000) dies after about 20 minutes. Left alone for ten minutes or so and it can be lit again, just to die once more. Is this a solenoid problem or a regulator problem? Or maybe both? The equipment is, I suspect, original. If either/both needs replacing, does anyone know what I need and where to get it? Thanks in advance for your help.
It's more than likely the solenoid. They are designed to shut themselves when they fail. It's pretty easy to swap one out. Trident MArine is a good source for these fixtures, and their products are carried in most chandleries.
