Old 02-14-2009
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
Not sure about ABS but PVC used as electrical conduit is UV resistant and is used outdoors all the time. Comes in many sizes at home depot.
  #12
Old 02-14-2009
Valiente's Avatar
Wood is nice indeed and it's not that hard to split a length of dowling, router out a bigger than the stay's diameter groove on both sides and to lash them as pictured with cut-down cable ties or small stuff.
The only caveat is that they need to rotate and this means they can't swell, so you will have to seal them inside and out and then varnish the outsides against UV. Also, wooden stuff here might look odd on more modern, "no exterior wood" designs.
Can't sleep? Read my countdown to voyaging blog @
  #13
Old 02-14-2009
Joesaila's Avatar
1977 Morgan OI 30
Joesaila is on a distinguished road
Duh!
Can't say how many times I had to run forward and unsnag the bowlin holding my jib. So I will put these on. PVC seems a lot more practical. I don't see the $40-+ value on the ads.
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
  #14
Old 02-14-2009
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
our boat came with simple PVC pipe. it's been in tropical sun for a while. No deterioration of the PVC.
If you have a keel stepped mast, I would think you could pull one shroud at a time with no problem, especially in calm conditions
  #15
Old 02-15-2009
gaha_1's Avatar
gaha_1 is on a distinguished road
use the pvc.You don't tune the rigg every year.You should drop the mast for the winter when the boat is on the hard
  #16
Old 02-15-2009
When I was young and had no money for boat parts, we used clear and coloured water hose to protect US, from the shrouds..especailly the guy on the trapeze, as sometimes we would nose dive and he was thrown into the shrouds...
We used thin diameter garden hose, and one season even clear tubing...
Personally, now..I don't really need it, because my shrouds are away from the sails, and I prefer the exposed shroud.
You may post attachments
You may edit your posts
Sealing my shrouds DwayneSpeer Gear & Maintenance 18 12-31-2008 09:45 PM
Force Inflatable Dinghy- Hypalon or PVC?? BlowinSouth General Discussion (sailing related) 2 08-04-2008 08:40 AM
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 05:46 PM
Spa flex PVC hose for sanitation hose TrojanSailor Gear & Maintenance 6 07-22-2007 08:51 PM
PVC and Epoxy billmac26 Gear & Maintenance 3 02-18-2003 12:12 AM
SEO by vBSEO 3.6.1
