02-17-2009
Bad idea... not ready for prime time as the charging system LiIon batteries require are considerably more sophisticated than what's currently available. Also, the batteries are very, very expensive.
Originally Posted by Whitebear
Hi
Consider Lithium Ion batteries. 2 x the charge for 1/2 the weight and size.
As for using one large battery box, the major concern with doing that is holding down all the batteries properly. With individual boxes, it is relatively easy to do. With a single large box, it is much more difficult.
As for Labatt's original question, I'd go with the Trojans suggested, unless you've got cash to spare, since you could probably get a modular Surrette-Rolls setup with the individual 2 VDC cells that would provide more power in the same space.
