Old 02-17-2009
FairfieldSupply's Avatar
Pump Builder
FairfieldSupply is on a distinguished road
Westerbeke W58 Perkins 4-154
Does anyone know if the Westerbeke W58 is a Perkins 4-154 painted red? I don't know the year of this engine but I am trying to locate a new or used valve cover for this. Any help would be greatly appreciated!
Thanks
Lewis
Old 02-17-2009
Valiente's Avatar
The way I found out my Westerbeke W-52 was a Perkins 4-135 and was also a Mazda R2 block as found in thousands of Mazda B2200 and Ford Ranger pickups was by getting diagrams of the Mazda block and photos of all three from the internet.
See here: http://www.sailnet.com/forums/259474-post32.html
Go to a Westerbeke owners' forum and use Google. This took me some time, but knowing I can repower by rebuilding an extremely common pickup diesel changed my entire perspective about owning a "vintage" engine.
You can also pay to join Boatdiesel.com. The truth is out there, apparently:
http://boatdiesel.com/Forums/Thread....hread_ID=33627
Can't sleep? Read my countdown to voyaging blog @
Old 02-17-2009
Pump Builder
Thanks Valiente!
Very helpful. The valve cover has pin holes all over and is tweaked. Well beyond brazing. I am still to green here to post with pics. Would be nice to show everyone.
Old 02-17-2009
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
If it has a relation to perkins, call Trans Atlantic Diesel; Perkins Powerpart
Big on Perkins parts and they know perkins.
Old 02-18-2009
Valiente's Avatar
Originally Posted by FairfieldSupply View Post
Thanks Valiente!
Westerbekes are also, as far as I can recall, often either Mitsubishi or Isuzu blocks. Ask around, because you definitely want to limit your purchases from them if you can.
Although they aren't as expensive as Volvo, home of the twelve-dollar washer.
Old 02-18-2009
PaulLefebvre is on a distinguished road
While I don't know for sure, as I don't have a W58 and haven't compared any part numbers, but my previous research has led me to believe that the block was made from a Mazda XA diesel, 2.5 litre. It was used in the Mazda T2500 truck. It was also a common engine used by Yale in their forklifts. You could try them for parts you need and let us know.
Paul
Old 02-27-2009
Pump Builder
Thank you for all your help!
I have on very good information that the Westerbeke W58 is in fact a Perkins 4-154. This was confirmed by a expert in England.
Old 03-01-2009
Valiente's Avatar
There you go. Now, all you need to find out is if it ever was also a Japanese tractor engine or fit into some small pickup and you won't have to pay "marine spare parts" prices.
Old 03-01-2009
Perkins 4.154 manual, handbook & parts manuals can be found here:
Endeavour Manuals
There are 2 versions of the Perkins 4.154. First one was US made and the more common one was Mazda. Look to see what fuel pump is on the engine. If it is a Diesel Kiki, it's a Mazda. Same as the one used in Mazda pick ups around the world.
The people at Trans Atlantic Diesel are very knowledgeable about parts and repairs and workarounds.
Old 06-16-2009
haamad is on a distinguished road
Perkins 4.154 or Mazda / Bosch VE Pump
Hi
I am trying to confirm what engine I have on my boat. The boat was home built in Canada, and I bought it from the second owner, who told me it was a Perkins 4.108. From looking at the 4.108 manual it is clearly not. I now believe it is a marinised Mazda T2500, or possibly a 4.154 for the following reasons.
The fresh water pump is the same as the diagram for a Westerbeke W58 which is I believe based on a 4.154 (though it is different from the pump in a 4.154 Engine Manual)
The side of the engine is marked XA, but I can not find an engine number.
The Injector pump is a Diesel KIKI, and looks the same as a Bosch VE.
One thing that concerns me is the amount of diesel that is pumped back into the tank. A pipe is connected with a Banjo fitting to the pump with an "Overflow Restriction" bolt. This pipe then leads back to the tank, and when the engine is turned on (even before starting up) the electric pump continuosly ticks and pumps diesel through this back to the tank, about 2 litres in 5 minutes. In the diagram I have for a VE pump, there should be a Pressure Control Valve, but mine does not appear to have one, merely the fuel supply line attached with a banjo fiiting. Does anyone know if this is the correct setup.
I found most of this information via this forum, so thanks in advance for the very useful posts.
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 11 04-19-2012 10:45 AM
Where To Get Parts For Old Westerbeke 4-107? BELLATRIX1965 Gear & Maintenance 9 11-17-2010 03:40 PM
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 10:10 AM
Perkins 4.108 shaft rotation jr438234606 Gear & Maintenance 11 05-21-2008 12:15 AM
Perkins Head Gasket & Hello to All islandzephyr Gear & Maintenance 3 05-21-2007 11:38 AM
