Old 02-19-2009
1970Columbia34's Avatar
1970Columbia34 is on a distinguished road
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
Hurth V-Drive Help
Hoping someone out there can help. We are repowering with a 1994 Remanufactured M25XP and a Hurth 150V vdrive. Pos A 2.99 ratio and Pos B 2.22 Ratio. My question is how do I know which way the selector shaft turns to get Pos A. And what turn prop will it be?
Scott
Old 02-19-2009
From the manual linked:
http://www.capedory.org/manuals/Hurt...ion_Manual.pdf
It appears that the "A" position is away from the input shaft on the straight-through version. Perhaps it's the same on the Vdrive.
Haven't had any luck finding more data on line yet..
1984 Fast/Nicholson 345
Old 02-19-2009
Perfect that is what I was looking for. Now the second question I did not see anything in there that stated if it would be a RH or LH prop. Any Ideas? Thanks Scott
Old 02-19-2009
RanAweigh's Avatar
Sea Dweeb
RanAweigh is on a distinguished road
Scott,
"A" is usually the opposite rotation of the engine output shaft, "B" is usually the same rotation as the engine.
If you were to stand over your engine, facing the bow, if the output shaft of the engine rotates clockwise then in "A" the propeller would turn counterclockwise or Left had Rotation position "B would turn the same as the engine or Right Hand rotation.
The gear box doesn't know what engine you are going to connect it to so the direction of rotation is determined by the engine.
Water Drive Mark Matthews Gear and Maintenance Articles 0 12-05-1999 07:00 PM
Water Drive Mark Matthews Cruising Articles 0 12-05-1999 07:00 PM
