10-24-2009
Hi scottyt,
That makes sense - and is simple. The only issue I can see that you'd have to watch is that in your first diagram, which I agree the redundancy makes safer, the current runs directly through the switch which could be an issue (many switches don't have current ratings that high). This could be solved of course by putting another relay in which is purely from that switch.
Using relays is an interesting alternative. I'm not sure which I prefer: relays or logic gates. They both have benefits and disadvantages. Logic gates are probably cheaper, but not significantly so.
Thanks for the enlightenment: I think it gives everyone a couple of great options.
As I pointed out in my original post, I think that the key here is the hysteresis that is in these systems. That stops the problems associated with just a single switch.
Cheers,
Paul.
