lexan thickness - Page 2 - SailNet Community
post #11 of 37 Old 02-23-2009
GreatWhite's Avatar
Trimmer- which Gasket sealant did you select from Mcmaster-Carr?
"The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labours hardest, so noisy and impatient when least effective". -- Henry David Thoreau
GreatWhite is offline
post #12 of 37 Old 02-23-2009
Junior Mumbler
G.W. I used neoprene rubber. I think it was 3/16 thick. I bought about 2' x 4' and made my own gasket, no sealant of any kind. I drilled holes through the plexi just a little larger then the screws and used a washer w/ a built in rubber gasket (from ace hdwr).No leaks! Btw Mcmaster Carr has so much stuff I recall I had to call for guidence.
"It's nice to be nice to the nice" Frank Burns
Trimmer is offline
post #13 of 37 Old 02-24-2009
One thing to remember. If you have to drill holes in plexiglass or polycarbonate, you really want to counter sink the holes on both sides so they don't become a starting point for a stress crack.
sailingdog is offline
post #14 of 37 Old 02-24-2009 Thread Starter
One of None
deniseO30's Avatar
I think the rubber gasket makes more sense then various types of caulk, mostly because the white shows through the plexi or lexan when it's overlayed like it is on mine. Painting it black was a thought also. Darn shame the original fixed port frames are gone. (one has to wonder what PO's were ever thinking)
My last project!
deniseO30 is offline
post #15 of 37 Old 02-24-2009
midlife crisis member
AllThumbs's Avatar
What are you talking about? The boats look way better once those frames are gone...
I sail.
AllThumbs is offline
post #16 of 37 Old 02-24-2009
The gasket approach is also more in line with what the various maufacturer's suggest on their installation data sheets. More time and effort than just gluing things together, so less likely to be found on a stock boat.
hellosailor is offline
post #17 of 37 Old 02-24-2009
Gary M's Avatar
I have not tried it but I would think that the butyl rubber gasket strips would work well. It stays soft and therefore gives as needed and still seals.
Gary
Gary M is offline
post #18 of 37 Old 02-24-2009
GreatWhite's Avatar
The gasket strips sound like a good idea. I am just about to replace 3 large ports with Lexan (AR abrasion resistant) and they have a 2.5 inch thick SS frame inside and out so the gasket will be covered. I had planned on using a goopy sealant, but after reading this thread I am considering other ideas!
post #19 of 37 Old 02-24-2009
Denise
If the existiing lexan is in good shape and you want to change to smoked 4 esthetic reasons, why not just overlay the new onto the old. That way even one eighth would be thick enough.
RXBOT is offline
post #20 of 37 Old 02-24-2009
Junior Mumbler
Wink
When I did mine I used sheet neoprene. That way I had a seemless gasket. I installed the full sheet, and then carefully trimmed the perimeter with a razor knife. Inside too. The usual trick is to use the external frames inside the cabin on the oposite port. Mine were plastic and broke apart removing them. I made some teak frames for inside the cabin. I'm a little impatient and drilled holes straight through the plexi .Oops no double countersink. As yet, no stress cracks either.( but I do have some stress)
This project took a looong time. Buy beer!
Trimmer is offline
Window gasket sealant.. groundhog Gear & Maintenance 39 07-11-2014 03:27 PM
FG layup schedule to achieve desired thickness dgr Gear & Maintenance 13 01-18-2009 11:50 PM
Lexan thickness for deck hatch Alden68 Gear & Maintenance 38 03-13-2008 06:05 PM
Teak Deck Thickness Mithril Gear & Maintenance 2 11-09-2005 04:17 PM
Restoring Lexan Surfaces Sue & Larry Gear and Maintenance Articles 0 02-10-2002 07:00 PM
