Rigging change? - Page 2 - SailNet Community
post #11 of 16 Old 02-23-2009
STARBOARD!!
KeelHaulin's Avatar
If you go with a triple block with cam cleat; you might have too little leverage. The cabin top winch adds about 20:1 of leverage so you would be losing that compared to the 6:1 of a triple block. I don't think a 4:1/8:1 (two speed) system will work in your situation because the boom is setup for 3 blocks/bails to distribute the mid-boom load. You might want to rig it so that one end is on a cam cleat and the fixed end that normally attaches to a becket is led back to your cabin top winch so you can also trim with the existing winch.
KeelHaulin is offline
post #12 of 16 Old 02-23-2009
It will be a six-to-one purchase, and the boat is only 28' LOA. You're assuming that it leads to a cabin top winch, which I don't believe it the case.
sailingdog is offline
post #13 of 16 Old 02-23-2009
blt2ski's Avatar
Not sure if it is possible. But if you SH like you say, you may find moving the traveler to the cockpit just in front of your wheel to be a better option yet. Then a 4-1 with a 4-1 micro would be right at your finger tips. Granted costlier, along with the traveler now being at your feet in the cockpit taking up some room, but possibly a better solution. Or even a 6-1 with 4-1 micro would be easy to pull on from the back of the boom.
I'd also concur with some of the others, leave the vang in place and rig the main sheet to what is appropriate for your needs.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #14 of 16 Old 02-23-2009 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
Could be from an earlier or later incarnation of the same boat... a mk II or something like that.
I grabbed the first drawing on line and it is of a Newport 28 II. Here's a scan of the drawing I have from the original documents that came with the girl. You can see that the rig is the same.
The mainsheet does lead to the cabin top winch, which is a nice thing to have. I think I will keep the rig as is, and find a way to improve the relationship between the boom vang and the rest of the rigging. Only costs money, right?
jaschrumpf is offline
post #15 of 16 Old 02-24-2009
STARBOARD!!
KeelHaulin's Avatar
Yes; but the sheeting is mid-boom and not at a single point which really increases the load on the sheet (first because it is mid-boom; second because the angles of the lines are not vertical when close hauled). If it were a simple triple block at the end of the boom then the sheet load would be much lower. The original setup for the Newports were for a cabin top winch; which multiplies it's leverage in addition to the 5:1 block setup.
My boat (a Newport 41) has the same setup; but the winch is a much larger Lewmar 42 two-speed. When we sheet it while power reaching it really requires the 2'nd speed to grind it in which means the loads on the sheet must be quite high. I've seen 41's with a cam block on the mainsheet; I can't really figure out how they sheet it while it's under any load.
I realize that his boat is a 28'; but the sheet loads will be similar at higher wind speeds (likely too high for hand-sheeting).
jaschrumpf-
Have you visited this website yet? - Newport, Neptune, Gulf sailboats built by Capital Yachts
Lots of discussion on the Yahoo group; subscribe via the link on capitalyachts.
post #16 of 16 Old 02-24-2009 Thread Starter
1975 Newport 28
jaschrumpf's Avatar
Yes, that site is where I got the first drawing of the Newport sail plan. I'll check out the Yahoo group, too.
Thanks!
Rigging Change donhallmon Other Brands 2 12-17-2008 05:05 AM
Rigging repair at-sea Lin & Larry Pardey Gear and Maintenance Articles 1 02-16-2008 01:28 PM
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 09:00 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 08:00 PM
Standing Rigging Storage Jerry Hammill Gear and Maintenance Articles 0 10-15-2001 09:00 PM
