10-27-2002
Solar panel
ldbarker,
If your panel is wired through a breaker, it will then have to be in the on position to close the circut in order to allow currant to pass.
The output from the pannel to the breaker should be wired somewhere directly to the batts. Check and see.You shouldn''t have to keep the batt switch in the on pos to charge the batts.
Remember that the pannel has to be perpendicular to the sun for best performance.You won''t get much on a cloudy day and,of corse,you won''t get anything at night.
Dennis
