Old 02-23-2009
johnp30 is on a distinguished road
eliminating seacock for overboard discharge
I have a 1973 Pearson 30. I primarily day sail and cruise a few weekends and a few weeks each year in the Northeast with one or two additional people on board. Wherever I spend the night I can typically find pump out pretty easily.
The boat is hauled and on the hard now. The seacock located in the bow for head overboard looks okay (alhtough there's green crud all over it) but is probably the original. That said, I'm just not a fan of holes in the hull. I also like simple systems and want to "clean up" the many hoses and y valves around the head because I never pump overboard and frankly, dont want to.
Long story short, can I eliminate that seacock and glass over. And in the process eliminate all "extra" lines...so, in the end there would be: a line bringing sea water in to the toilet, a line from the toilet to the tank, a line from the tank to the deck for pump out. No y valves, no vented loops etc etc etc. Resale is not a concern.
Old 02-23-2009
motion300 is on a distinguished road
yes of ,You know your needs for pump out
Old 02-23-2009
John—
Yes you can glass over the opening after removing the seacock. You would still need a vented loop for the head intake line.
Old 02-23-2009
Thanks sailingdog, appreciate the fast reply. Right now there is a 3/4 inch hose that brings the water into the toilet. Is this the line that should receive the vented loop before the toilet?...or are you referring to the line from the toilet to the tank??
Old 02-23-2009
Maine Sail's Avatar
The vented loop for the head should go between the pumps outlet and the back of the toilet bowl. Do not install it on the suction/inlet side of the pump as this will cause the system to just suck air in through the vented loop. Most heads come with a short pre-made hose that goes from the pumps outlet around the back of the bowl to inject water into the bowl for flushing. Remove this hose and insert a vented loop in its place..
______
-Maine Sail / CS-36T
Old 02-25-2009
StanleyCup is on a distinguished road
Is there any consideration to the resale value if you eliminate the ability to discharge overboard? Someone who wants this ability would likely not consider a boat that does not have this ability.
Old 02-26-2009
Omatako's Avatar
Omatako will become famous soon enough
Since you say you're not concerned about resale, I'd be more concerned that having to depend on pump-out would make long trips away from main centres a problem becuse if you have no pump-out and no self-discharge, a full tank leaves you with no heads.
The fitting is still good, why mess with it? You're just limiting your options.
Arthur C. Clarke
Old 02-26-2009
scottbr's Avatar
scottbr is on a distinguished road
StanleyCup, like myself, is in the Great Lakes and at least a 2-3 week trip to get into water that we could actually dump overboard. I removed the hose to my macerator, closed off the opening in the holding tank and removed the macerator due to permeated hose and smell in the aft cabin. I doubt that reasale would be affected as most of the boats in this area tend to remain in this area.
Old 02-26-2009
Dick Pluta is on a distinguished road
I owned a '76 P30 that was had what was the OEM setup with no Y valve or overboard capability. I couldn't pump overboard. For 20 plus years on Lake Michigan, no problem. I moved east to NJ, no problem. Pumpout stations everywhere. Then I went down the ICW. Big problem. Apparently the EPA gave marinas grants to install pumpouts. When they broke down and the marinas had to fix them on their own dime, they just stopped offering the service. Getting pumped out was not easy. Here in the Bahamas....fageddaboutit! If you have it, I wouldn't get rid of it, even if you don't use it. The day may come when you need it.
Dick Pluta
AEGEA
Nassau, Bahamas
Old 02-26-2009
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
The vented loop should be above the water line or it will not vent as designed.
Hey, can one of you guys pass me a crab?
Lubricant for seacock FrankTugw2ell Gear & Maintenance 19 07-07-2011 09:05 PM
Assemble thru-hull & seacock...how? flyhop Gear & Maintenance 10 04-09-2008 04:53 PM
Seacock question saltypat Gear & Maintenance 3 07-21-2007 02:59 PM
No Discharge Zones engcon General Discussion (sailing related) 1 01-11-2007 11:52 PM
Dumping on Sailors Don Casey Seamanship Articles 0 08-15-2002 08:00 PM
