-   -   winch handle (http://www.sailnet.com/forums/gear-maintenance/51821-winch-handle.html)
marthajewel 02-23-2009 12:14 PM
winch handle
1 Attachment(s)
My father and I are restoring a 1974 Macgregor Venture 25 and are almost finished. I have searched high and low for a winch handle for the stock winches that are on it. I have attached a pic of the winch. Does anyone know where I could find a handle for this un-marked winch. Or maybe someone has one they are willing to part with.
scottyt 02-23-2009 12:34 PM
i would call bacon and assoc in annapolis maryland, get an email addy and send that pic. they should be able to identify it, and maybe have a handle for it.
if they dont, they sell used stuff to you might be able to get a modern one for a decent price
killarney_sailor 02-23-2009 04:11 PM
snubber winch?
Is it possible that it does not use a winch handle? There are some small winches, called snubber winches, that are designed just for holding the sheet as you pull it is manually.
sailingdog 02-23-2009 04:20 PM
I think KS might be correct. The top of that winch doesn't look like one that accepts a handle.
marthajewel 02-23-2009 07:06 PM
Thank you all, I will let you all know what I find out about this winch. I will be checking out snub winches tonight.
timebandit 02-24-2009 10:40 AM
How about a flat bar that would fit the cut out and a hole to fit over the center and a handle.
It looks like the handle could be lifted off the driving dogs without comming off the center part.
Just a thought.
marthajewel 02-25-2009 09:46 AM
I was thinking about trying that. Thanks for validating my thoughts. I will make on out of steel to see if it works. If it does I will weld one out of stainless. ( i teach sculpture and have tig that will do it)
Boasun 02-25-2009 10:57 AM
You could have a machine shop punch one out for you. Or if you are willing to learn a new skill. buy the stock and do it yourself.
SEO by vBSEO 3.6.1
